-   -   Does anyone have a detailed schematic of the Carrera 3.2 Alarm Control Unit? (http://forums.pelicanparts.com/porsche-911-technical-forum/1108796-does-anyone-have-detailed-schematic-carrera-3-2-alarm-control-unit.html)
xarkon 12-16-2021 08:12 AM
Title says it all. I'm looking for a detailed schematic of the Carrera 3.2 alarm control unit. I've done some searches and come up empty; the representations I've seen are superficial (look, there's logic inside!). (The why: I am just curious.)
If one is not available - if someone has a dead ACU that they would be willing to send me, I'd be interested in opening it up to trace the circuit and draw a schematic. Assuming, of course, that the unit can be opened without destroying it and doesn't have the circuit board gooped, IC numbers removed, etc.
Thanks,
Dave
mtb001 12-16-2021 09:34 AM
I have a non working one that i can send, if i can find which box it's in.
Will check today and PM you.
xarkon 12-16-2021 10:34 AM
Outstanding. Will look for your PM. Thank you!
mtb001 12-18-2021 07:32 AM
alarm module
http://forums.pelicanparts.com/uploa...1639841422.jpg
I think this is the alarm module; removed when i added keyless entry.
xarkon 12-18-2021 08:03 AM
Thanks - I responded to your PM.
FrankM_ 12-18-2021 09:34 AM
Looks like a lot of the old diode-logic going in there. I would be interested in the schematic if you draw one up from the pcb.
Side question : did cars that did not come with the alarm unit always have the alarm unit wiring harness ? I recently ripped my front blower out in search for this harness to connect a gos tracker but could not find the harness where it is supposed to be if you follow the porsche wiring diagram (my car is a 1985 Carrera)?
mysocal911 12-18-2021 10:00 AM
It's an analog design using a quad op-amp.
xarkon 12-18-2021 10:13 AM
Yes, if I can trace the board, I will post the schematic. As mentioned, the IC on the board is a quad op amp.
I don't know the answer on the harness.
mysocal911 12-18-2021 11:07 AM
Originally Posted by mtb001 (Post 11550482)
That's the door lock module. Here's the alarm module;
http://forums.pelicanparts.com/uploa...1639854358.JPG
