Question Direct Fit CARB catalytic converter 1988 911 3.2
1988 911 3.2. 170k miles…original cat is bad. Any suggestions for a well made direct fit cat that is certified for…California?
Old 10-19-2022, 09:36 PM
I installed this model in 2016 on my '87 (222K miles at the time) and it did an amazing job.
DEC Cats, CARB legal part # PO82605
Our host used to sell these, but I don't see it listed now. The website for DEC has this still listed as something they can build to order, FWIW.
~Brian
1987 911 Carrera
Old 10-24-2022, 03:14 PM
big fan of M&K's active cat, they have a CARB version as well. definitely wakes up my targa's exhaust when I get "on" it. https://mkexhaust.com/active-exhaust-with-carb-catalytic-converter/ (but looks like it's not currently available)
Old 10-25-2022, 06:57 AM
NOT CARB compliant for sure.
Old 10-25-2022, 08:50 AM
Flynt's Avatar
I used the same - only one I could find! I got that one for ~$350 (wholesale) from my supplier, back in 2020. They list it at $1135 today. Rock auto says it's $1376. Guess I should have bought them all. If you hustle, you may be able to find a vendor with one in stock at the old price. Or maybe somebody here will lend you a good one.
I may still have a good, used one, actually. Slightly rattly but will get you through a smog check.
Old 10-25-2022, 10:13 AM
Curoious about what leads you to that conclusion (especially since link specifies the cat IS carb-compliant? I also believe several forum members had these on CA-smogged cars. The bypass valve is downstream of the cat. Although not in CA, my NON-carb active cat has passed CO smog several times w/o issue
Old 10-25-2022, 10:22 AM
Tags
911 , catalytic converter , exhaust system
