-   -   Missing components in relay (http://forums.pelicanparts.com/porsche-911-technical-forum/1108914-missing-components-relay.html)
mojarra2929 12-18-2021 11:09 AM
My safety belt warnig light stays ON all the time. My car is an 1985 european version without buzzer and wiring to the seat belt contact. It is a timing relay that is supposed to turn OFF the warning light after 2 or 3 minutes.
I opened the control relay and found out that some components might be missing. Or may be not. Not really sure.
:eek:
Can you please help me?
Thanks http://forums.pelicanparts.com/uploa...1639854466.jpg
http://forums.pelicanparts.com/uploa...1639854551.jpg
redridge 12-18-2021 11:18 AM
ummm, I pulled my relay out... old school I guess.
mojarra2929 12-18-2021 11:27 AM
Is it supposed to have a coil or not? It is just a timer relay.
Miguel
911 carrera, year 1985
proporsche 12-18-2021 11:33 AM
Miguel .put the key on and disconnect the battery ,this will reset the warning light.do this and report
if you like to have that relay ..i have plenty of them..but it is not important to have it there..
Ivan
proporsche 12-18-2021 11:38 AM
also European models have this wire in there...http://forums.pelicanparts.com/uploa...1639856218.jpg
redridge 12-19-2021 10:34 AM
another test is to check continuity at the seat belt wiring under the seat (check both seats)... I think the limit switch is closed when there is no buckle in place. It could be that instead of the relay.
wazzz 12-20-2021 02:49 AM
No missing components inside de relay, at least for your car. The PCB was probably designed for different car makes or models that needed additional components or features.
rpk55 04-09-2025 03:14 AM
Faulty relay
Proporsche: In your collection, would you have one of these relays? 88 911 , 901 618 102
Robkammer16@gmail.com
coupehttp://forums.pelicanparts.com/uploa...1744193991.JPG
proporsche 04-09-2025 05:12 AM
hi Rob yes i do .....only not 87 but 1982 otherwise the same
Ivanhttp://forums.pelicanparts.com/uploa...1744200686.jpg
