-   -   67' 912-6 Conversion Charging Issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1108930-67-912-6-conversion-charging-issue.html)
oldskool912 12-18-2021 02:56 PM
Like the title says I swapped out the 1.6L 4cyl for a 2.1L 6cyl. I was given a 964 fan/alt and decided to go down that road because I like the look of the fan.
For starters battery voltage is 12.3V. Since I'm running an MSD I can watch the voltage drop slowly while the engine is running. Voltage does not change as I raise engine RPM's.
The charging light on the dash is not turning on when I turn the ignition to the "on" position. I confirmed 12V from the ignition switch at the charging light and I have grounded the D+ blue wire from the alternator to the charging light and the light does come on.
Since this is a 115 amp alt. I ran a 4ga "+" cable from the alt. to the starter terminal. I also ran a 4ga "-" cable from the alt. housing to a starter mounting bolt for a solid ground.
To confirm the chassis ground from the trans to the chassis is not the culprit I hooked up a temporary additional ground from the trans to chassis. Still not charging.
I have a new battery and I also replaced the alternator.
I feel there is a ground issue because with the alternator not tuning, the 12V from the D+ side of the alternator should be going to ground which should activate the charging light.
Is there something that I'm missing?
Thank you all for your help. SmileWavy
john walker's workshop 12-18-2021 03:24 PM
The blue D+/61 grounds through the brushes and when the engine is running, that ground becomes hot and the light goes out. Must not be grounding through the brushes.
