Fan Belt Proper Tension
I am replacing my fan belt as a part of a valve adjust on my '88 Carrera 3.2. I have 5 shims under the pulley and one on the outside and the new belt is quite tight. Does a new belt typically loosen early on or should I move all 6 shims under the pulley?
Just a note, the old belt had four shims under the pulley and 3 outside?? not sure why someone went with 7 total shims but I assume 1 additional on the outside wouldn't affect anything.
Old 12-03-2021, 01:16 PM
Number of shims........
Toby,
I changed the old fan belt of my son’s ‘87 Carrera 3.2 last weekend and found 7 shims too. But my SC’s have only 6 shims. Curious to check the number of shims in my ‘89 cabriolet.
Tony
Old 12-03-2021, 01:28 PM
proporsche's Avatar
always only 6 shims...unless the guy like to have spare shimm handy..just kidding..really 6 it is
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-03-2021, 01:36 PM
Use the correct belt, CONTITECH AVX 10X710. Start with 3 & 3 shims. Total six only. If it squeaks at all, go to 4 & 2 or until it stops squeaking.
As a personal note, and not all will agree, I run it as loose as possible and tighten it only enough so it doesn't squeak. I think if it doesn't squeak, it's not slipping.
Old 12-03-2021, 01:56 PM
47silver's Avatar
Check out gates krikit 91107 it is easy to use
1975 911S Targa
Silver Anniversary Edition
Old 12-03-2021, 03:16 PM
I have the correct Porsche 710 belt. I’ll move all 6 shims under the pulley and see how it feels.
Old 12-03-2021, 03:46 PM
Racer
winders's Avatar
The "trick" I used was to get the belt tight enough so I could not twist it with my thumb and index finger no more that 90 degrees.
The 10x710 belts don't fit into the pulleys as nice as the OEM 9.5x710 belts....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 12-03-2021, 04:05 PM
proporsche's Avatar
^^^^^^^^^^^^^^^^^this^^^^^^^^^^^^^^
Old 12-04-2021, 12:38 AM
Bill Douglas's Avatar
After you have fitted the new belt and done a few drives, check the belt tension again. They bed in slightly and become a fraction more lose than when you first fitted it.
Old 12-04-2021, 12:54 AM
Thanks, I’m going to put all 7 shims inside the pulley and see what that looks like. I’m wondering if mine had 7 shims because they needed all of them inside the pulley to get enough slack? Will watch closely first couple hundred miles.
I am amazed how much detail is left out of the articles regarding this maintenance item. Nobody mentions how the spindle on the fan is keyed and how any outer shims have to be aligned correctly or you distort the spacers.
Old 12-04-2021, 06:15 AM
It's a bit of an IQ test Toby, and I must admit I failed the first few times. I had trouble balancing the shims on the shaft but found a glob of sticky oil stuck them together making the job a lot easier. Mine can either be too tight or a little too lose. I opted for the little too lose and sprayed some "belt dressing" on it which makes it not slip.
Old 12-04-2021, 11:00 AM
I use the krikit also for my Vilano belt driven bike. Works the same as for my 911's
Easy to use and accurate.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 12-04-2021, 04:09 PM
Good info.
What tension do you set your belt to. on the gauge?
Cheers,
Frank
76 911S
Land Rover 110 Defender
Old 12-05-2021, 10:22 PM
47silver's Avatar
I set mine to 15-23 Kg cold which is ~ 30-50 pounds.
when you press the Krikit properly it actuall clicks and the lever will move to the line for the tension.
I set it about 30 pound or 15kg.
1975 911S Targa
Old 12-06-2021, 08:19 AM
Great information, thanks very much. I have ordered the tool.😀
Cheers,
Frank
Old 12-06-2021, 11:38 AM
You can also use your smartphone with an app from Gates.
It senses the harmonics when you lay it on the belt and snap it.
98 Honda Prelude
22 Honda Civic SI
Old 12-06-2021, 11:48 AM
I looked at that app and it asks if I'm tensioning a bicycle or a motorcycle.
Old 12-06-2021, 12:19 PM
^^^ Understand....I was looking at it for my Vilano belt bike. I bought the Krikit instead.
98 Honda Prelude
22 Honda Civic SI
Old 12-06-2021, 12:23 PM
98 Honda Prelude
22 Honda Civic SI
Old 12-06-2021, 12:29 PM
I replaced the fan belt on my car when I first purchased it some yrs. ago.
I did not realize one of the shims had fallen down into the shroud when I was removing everything.
I like flash lights.
Old 12-06-2021, 04:13 PM
