'73 911 T Targa
Co-mingling motor oil and gear lube
Background:
I have a setup I made that I call the "Oil IV". It's a bucket with a hose attached to the bottom. The other end of the hose has a fitting with a valve and a magnet that holds it in the oil filler. I put the appropriate amount of oil in the bucket, raise it above the level of the fill, turn on the valve and the oil runs in - kind of like an IV. Of course the hose is never 100% completely emptied of oil.
So far, I've only used it for engine oil. But, now I have the desire to use it for 80W90 gear lube (not in the 911).
Will it matter if small amounts of residual engine oil from the IV bucket get co-mingled with the gear lube?
Conversely, will it matter if small amounts of gear lube get co-mingled with engine oil next time I use the IV for an oil change ?
Any information is appreciated.
Old 12-26-2021, 03:09 PM
If you’re talking a few tablespoons I wouldn’t give it a thought.
Old 12-26-2021, 07:14 PM
Dummmmmb
Old 12-26-2021, 08:21 PM
gearhead
Nbd.
Old 12-27-2021, 12:22 PM
Ctopher's Avatar
If you were concerned why don't you just open your valve and spray some brake cleaner down the tube to flush it out? Takes like 2 mins to do and let it dry and then you don't have to worry about it.
Old 12-27-2021, 01:28 PM
It's a 914 ...
stownsen914's Avatar
Make sure to keep that bucket super clean
Old 12-28-2021, 03:12 AM
