911 Rear Fog Light Wiring
I just purchased and installed a rear fog light for my 82 911 SC. There were no wiring diagrams/instructions supplied.
Any ideas how to connect correctly to the front fog lights?
Thanks.
Peter
Portland, OR
Old 09-15-2005, 03:25 PM
Early_S_Man's Avatar
Porsche Crest
Peter,
There is a spare wire [for USA cars] dedicated to the rear fog lamp in the bundle going to the left rear tail lamp assembly at the rear bulkhead connector at the rear left corner of the engine compartment. It is folded and taped near the fog lamp switch, and also at the wire bundle going into the left tail lamp assembly.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-15-2005, 03:54 PM
Brillo's Avatar
Thumbs up
Awesome! This is a project I have been putting off because I had no information on how to make it work. Now I can put on the list to complete
Ray H.
1979 911SC Coupe
2000 986
Old 09-15-2005, 03:59 PM
Thank you Warren!
Peter
Old 09-16-2005, 02:17 PM
steve911's Avatar
Peter--
Did you ever get this to work? I'd be interested as its something I've contemplated.
Warren--
You are (as always) a wealth of information. I need to go looking for this wire!
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 11-07-2005, 09:38 AM
mojarra2929's Avatar
Any way to recover the rear fog light wiring diagram ? It shows as not available.
Old 01-02-2022, 07:03 AM
I have this diagram for '72 which might be similar and might help.
Old 01-02-2022, 07:48 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
No need for a wiring diagram. the green/white wire is there behind the bumper, and the other end is there behind the blower in the trunk. It's just waiting to be connected!
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 01-04-2022, 12:47 PM
Perpetual Reassembler
2jmotorsports's Avatar
True story.
https://forums.pelicanparts.com/porsche-911-technical-forum/1050028-impact-bumper-license-plate-lights-wiring.html
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 01-04-2022, 12:50 PM
Hi Peter:
I added a rear fog light to my 78 SC about 2years ago. This is how I did it. I purchased the fog light and bracket from Pelican, and firstly found out that my car did not have any factory wiring in place for the rear fog. Also I had an ugly hole in the dash where the PO had installed a non working toggle switch for the power antenna. So I also purchased a Hella (illuminated) dash pull switch from Pelican to use as the switch for the rear fog. I ran a new wiring harness under the car from front to back using 2 conductor trailer wiring which comes in a weather proof sheath. I clipped the wiring to the AC hoses so it is not noticeable at all. I also fused the circuit and mounted the new fuse in the fuse panel in the frunk. I have attached my wiring and installation notes FYI. Works great, very bright too. I am also thinking about a mod to it this winter, where I am going to modify the circuit so that the rear fog acts as a 3rd brake light , when it is not in fog service. (There more brake lights back there, the better I think!). Any questions- just ask!
Karl
Old 01-06-2022, 05:02 AM
