-   -   Idle issue '74 2.7 cis (http://forums.pelicanparts.com/porsche-911-technical-forum/1110093-idle-issue-74-2-7-cis.html)
Overseas72 01-06-2022 06:10 AM
1974 911 TARGA 2.7 CIS .
I've recently developed a idle issue. It has always taken a while to warm up to idle 20-30 min. Recently it has started to just cut off when i come to a stop . I can restart the engine and it will idle for a short time. The engine will serge up above normal idle then fall and cut off .
I have changed the gas - same problem
Showdown 01-06-2022 05:11 PM
You need to do a thorough test of your CIS with pressure gauges, until then you’re just guessing.
Look at:
Pelican thread “Cis for dummies”
Jim’s basement workshop
Once you have data, the problem can be identified and rectified.
