Taillight Reflector Rust?
The reflectors (see pic red box) for my taillights have suffered rust since the rubber seals have suffered deterioration (see related below). Left is toast and right one just has one corner starting to rust. Can these be replaced? Does not look like they come off? By-the-way, this picture is not my taillight – used it for illustration. I applied some dope that stops the rust and used something I found that’s akin to shinny mirror like chrome with sticky adhesive on the back as interim fix. Seems to work pretty well! Maybe I am done?
Ok, know to fix the root cause. Do the rubber taillight seals need any kind of adhesive when applying new ones? Is so, what do I use? Thanks for input! Jason 88 911 Cab http://forums.pelicanparts.com/uploads/trust.jpg |
Tail Lights
Sure, they are easily replaced. Parts are available either new
from Pelican or used from almost any dismantler. Unless the holding screws are rusted tight, in and out in less than 30 minutes. |
Used tail lights
I should have looked at Pelican classified first...found this just
minutes after I answered you...go here: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/110999-parts-sale.html |
| All times are GMT -8. The time now is 06:59 AM. |
