How to tighten Fuel door latch
Hi,
I have a 1972 911t - fuel door latch inside the fuel door is loose. So that the door when closed does not sit level. It appears that a bolt or screw is holding it in place and has worked its was loose.
How do I access the screw to secure the fuel door latch? Do I need to remove the fender? How hard is that to do?
Old 03-08-2022, 07:50 PM
Also, for the life of me, I cannot find how to search this forum? Where is the search button lol?
Old 03-08-2022, 07:53 PM
A 5mm cap screw holds the latch mechanism on. Access it from the inside of the fender.
It’s a real soft metal / strips easy. I removed my fender to grind it off. Replaced with conventional hex bolt
Old 03-08-2022, 08:05 PM
Thanks, was able to get a 5mm bit in the cap screw and then a 1/4 wrench onto the bit. That was tight access - appreciate your help!
Originally Posted by djanis99 View Post
Hi,
Old 03-08-2022, 09:17 PM
Jeremy Brooks AKA VWLOOSENUTS
***My cars are built to meet my approval, not yours!! My money, my cars, my happiness.
Old 03-09-2022, 09:03 AM
