-   -   Does anyone use any sort of starter inhibitor for theft protection? (http://forums.pelicanparts.com/porsche-911-technical-forum/1110412-does-anyone-use-any-sort-starter-inhibitor-theft-protection.html)
markmalin 01-11-2022 09:11 AM
Sorry - I have no idea what this would be called, but sometimes I've thought of figuring out a way to hide a switch somewhere which would disable the car from starting. We've had a few carjackings locally, too, which makes me think it would be nice to disable the car before I'm thrown out a gunpoint ;). That or start carrying a 9mm...but who knows if I'd have the presence of mind to use one in the heat of the moment.
Does anyone use such a device (whatever they are called)?
Mark
Rodsrsr 01-11-2022 09:26 AM
Its called a kill switch, but advertising the common locations on a public forum is probably not the best idea....
markmalin 01-11-2022 09:37 AM
Can someone PM me details, then?
Mark
911SauCy 01-11-2022 10:39 AM
I think the patternless shift knob on the 915 box is sufficient :)
cortney 01-11-2022 10:47 AM
I have a fuel pump cut off switch. Basically its a toggle switch in series with the primary (low voltage) side of the fuel pump relay.
Fairly simple to do and mount the switch wherever you desire. Just don't forget to flip the switch when you try to start your car, I forgot once and was in panic mode for a little while until I remembered the switch.
jmz 01-11-2022 10:52 AM
Kill switch doesn’t stop a wrecker.
GH85Carrera 01-11-2022 11:02 AM
A kill switch is good to stop a crack head or kid. It will not slow down a true pro by much.
shamrok 01-11-2022 11:31 AM
Fuel pump cutoff switch and an Apple AirTag hidden away are what I'm doing. If someone really wants the car, I'm not sure there's much more to stop them.
Joe Bob 01-11-2022 11:32 AM
Your stick shift will stop most. No shift pattern on the knob next. Beyond a Denver boot you’ll be on your own.
markmalin 01-11-2022 12:07 PM
Thanks guys. I may consider a fuel relay switch like cortney mentioned.
I need to look up the Apple AirTag. I haven't heard of those
Jeff Higgins 01-11-2022 12:21 PM
MFI stripped of all "automatic" start-up and warm-up compensation, replaced by full manual control. I would defy anyone to start my car before the battery dies, unless I run them through the procedure.
markmalin 01-11-2022 12:22 PM
I would like to have that level of confidence with whatever scheme I come up with! ;)
Hi_Fi_Guy 01-11-2022 04:40 PM
+1 kill switch (starter or fuel pump). Always do this on any vintage car I own. Especially open top cars.
+1 hidden Apple AirTag or other tracker
Review your collector car insurance policy annually and adjust agreed value as needed.
pavegeno 01-11-2022 05:19 PM
I got my factory installed alarm working. Pretty rudimentary system, but probably old enough that no one expects them to still be working or installed.
87maniac 01-11-2022 05:20 PM
http://forums.pelicanparts.com/uploa...1641950377.jpg
snbush67 01-11-2022 08:37 PM
123 distributor has a remote disabler built into a phone app with Bluetooth connection.
snbush67 01-11-2022 08:40 PM
http://forums.pelicanparts.com/uploa...1641962389.jpg
Hi_Fi_Guy 01-11-2022 09:51 PM
I forgot about that. Always thought it was a clever feature.
Coastr 01-12-2022 06:23 AM
Up to date insurance policy, don’t drive or park in dodgy areas.
pmax 01-12-2022 06:15 PM
They'll simply tow it.
