brittbolen's Avatar
Question Question about fuel vent/evap "Y"s (911.201.167.00)
I’ve got an obscure part question for ya'll…
911.201.167.00 <— this is the “y” connector in the fuel eval/vent system on my 70 911E… this is the big one closest to the tank, with 2 large connections and 1 small, as opposed to the other 2 which have all small connections.
I’m replacing all my old hard, cracked plastic evap bits and I was looking at this “Y” and it’s not really open inside… the small arm of the “Y” only has a pin prick opening into the main straight through section of the “Y” the other 2 Ys have full size openings inside…
If you have one of these on the shelf can you look at it, see if it’s open all the way through? You just need to look through it, and see if there is a opening for the small arm… thanks!!!
Pics for reference in next post...
Thanks!!
Old 01-09-2022, 01:40 PM
brittbolen's Avatar
Three Y connectors. Circled is where there is just a tiny opening, just a point of light
View inside the large Y, no opening
View inside small Y, opening clearly visible
Old 01-09-2022, 01:49 PM
HarryD's Avatar
I can't answer your question based on these pictures but it is possible that the big Y has a built in restrictor. Look at the area closely to see if it shows signs of damage or was molded that way.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-09-2022, 02:11 PM
brittbolen's Avatar
Honestly it’s hard to tell, maybe it’s intentional so that slosh, expansion, or overfill tends to head towards the expansion chamber first otherwise the flow would go towards the vapor chamber (behind the headlight) first as it is lower in the system…
Old 01-09-2022, 03:52 PM
brittbolen's Avatar
Anybody? Thanks!
Old 01-12-2022, 07:07 PM
