1988 Carrera Cabriolet Adjustment
Does any one know if there is a guide to adjustment or setting up an electric top.
I found this in an old post from 2009: Pelican offers a Tech & Spec Guide for Cabriolet Tops (1983-94), 63 pages, 8.5" x 5.5" softbound http://www.pelicanparts.com/catalog/shopcart/BOOK/POR_BOOK_bkpbuy_pg2.htm Which is - PORSCHE 911 SC & TURBO GOLD PORTFOLIO 1978-1983.
Shorty 1988 Carrera Cab |
I have not seen a book completely dedicated to the adjustment of the cabrio top, but I suppose its possible. In my 10+ years of ownership I still think the best source of information is this forum.
Do you have a specific issue with your top?
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Yeah having lots of trouble I sheared some of the teeth on the LHS control arm from the box which put everything out of alignment which let to the snapping of the main folding bow. Now after having the bow carefully welded back together (not paying the $2000 for a replacement) the steering arms don't align to put the pivot bolts back in, they are not out but much maybe 1/4 inch so looking for some adjustment. The only thing I can find is the lengthening /shortening adjustment with the 17 mm nuts.
Maybe some pics would help. Are you saying that the control arms on the two sides aren't exactly in synch? If thats the issue, one solution is to temporarily disconnect the drive cable from one side, and use the power button to move the other side until they are lined up. Sorry if that's not exactly what the issue is. I had to do that once with my top to realign the arms.
Not sure if it will help you but Sealing of 911 Coupe Targa Cabriolet has a lot of information on sealing our cars.
I did manage to find a Service Information Bulletin - WKD 4512.20 for a '83 911 SC which was a great help.
