-   -   Part Number Request- Fuel Line Divider (http://forums.pelicanparts.com/porsche-911-technical-forum/1111108-part-number-request-fuel-line-divider.html)
KTL 01-20-2022 01:24 PM
I've looked all throughout the parts diagrams and I can't find this part. Usually i'm pretty sharp with the PET diagrams but this one has me defeated.
Does anybody know the part number of the plastic clips/dividers/brackets that keep the steel supply and return lines separated in the engine bay? My car is an '86 Carrera.
These are the white rectangular pieces that are about an inch wide and maybe 3 inches long, held against the body with bendable metal tabs. The fuel line sits in the reliefs to hold them in place. See picture below with the green oval where they are usually located. Sorry I don't have a picture of the actual divider installed.
Sometimes the part number is on the actual part, but I don't believe that's the case with these things? I think mine were crispy and crumbled apart when I removed them, and I think I tossed them in the trash. So I don't have them handy to check for a part number
Thanks!
Kevin
http://forums.pelicanparts.com/uploa...1642712752.jpg
proporsche 01-20-2022 02:12 PM
the part number. 99951109302.looks like NLA..how about this one that might work for you?
99950752140
Ivan
bkreigsr 01-21-2022 11:59 AM
....nice work Ivan !!
KTL 01-21-2022 01:01 PM
Thanks for those numbers Ivan. I looked up the 2nd number and it's from a 996/997 application. Might be able to make that work, as it has the same type of reliefs in the plastic bracket to support the lines.
