Agfours
agfours's Avatar
Belly pan / front sway bar bolt stripped
I recently pulled down the front belly pan / sway bar to reach the fuel pump, and when I reinstalled, noticed that the bolt that holds the long part of the sway bar on the driver's side (which also holds the metal belly pan) was stripped and won't tighten when fully seated. Looks like the mounting side thread is part of the body, so I'm thinking I'll need to use a Heli-coil / time cert, after cutting a new thread.
Just pinging the forum in case I'm missing anything/alternative approaches, or things to keep in mind/concerns.
Anyone know what size Heli-coil/time cert off hand?
TIA!
Paul
Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..."
Old 02-07-2022, 08:35 AM
porsher
aston@ultrasw.c's Avatar
lets say it's an M12-1.5 bolt. If you buy an M12-1.5 thread insert kit you will get a drill, tap and insert that will fit your bolt.
The outside thread form on the insert will be much larger than M12 but you will end up with what you want.
Two tips, thoroughly lubricate the drill and tap, have another pair of eyes looking at 90 deg to you (hopefully between the two of you it will be perpendicular)
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 02-07-2022, 09:57 AM
