Hole in oil thermostat
I was changing the oil lines to the thermostat on my 82SC and noticed a hole inside the line coming in from the oil reservoir. Is this do to wear? I assume this is not normal.
Old 04-08-2022, 01:03 PM
Normal.
206 637 4071
Old 04-08-2022, 05:22 PM
Abnormal wear and tear........
Joe,
The hole in that cavity should look more like a circular or roundish opening. Find a new auxiliary thermostat and compare it. I have two (2) boxes of auxiliary oil thermostats and every one of them has circular holes.
Tony
Old 04-08-2022, 05:53 PM
The one I looked at looked the same as posted.
206 637 4071
Old 04-08-2022, 06:19 PM
Some of the auxiliary oil thermostats that I used for my experiments:
Look very closely inside the cavities and you will see the circular holes.
Tony
Old 04-08-2022, 08:22 PM
7783911's Avatar
mine is like Tony's, circular
but feel with finger, if the bore is smooth then you should be ok
Old 04-09-2022, 03:27 AM
The bore seams smooth and temperature gauge always reads normal.
Should I change it?
Thanks for the help.
Old 04-09-2022, 03:39 AM
Should I change it?
Joe,
The opening or passage holes in your auxiliary thermostat that we are discussing might look ugly but they don’t have any significant effect to its OPERATION. There is no slide valve or moving parts involve in this section of the auxiliary thermostat housing. Only flowing oil from engine going IN and oil going OUT back to the oil tank.
Perform an oil/water bath test to determine the operating temperature range of the thermostat. Generally, it would start to OPEN/CLOSE @185°F and fully OPENED/CLOSED @200°F.
Do not be distracted by the OPEN/CLOSE terminology I used. This was simply like a glass of water half filled or half emptied.
Tony
Old 04-09-2022, 06:08 AM
Old 04-09-2022, 08:13 AM
