-   -   Help identifying cylinders (http://forums.pelicanparts.com/porsche-911-technical-forum/1111505-help-identifying-cylinders.html)
derm.1785 01-26-2022 01:27 AM
Hi. I’ve managed to buy a set of Mahle cylinders for a rebuild that I’m doing. These were sold as 95mm but they measure 98mm. They don’t look like they have been previously bored out and they don’t show any skirt markings. I can’t see them mentioned on here as anything other than 95mm. I was wondering if they were aftermarket big bore???? The markings stamped are 95ZN1 W16 wth A8 below.
icarp 01-26-2022 05:54 AM
pics would be a big help
derm.1785 01-26-2022 07:15 AM
I tried to upload some pics but couldn’t. I’ll try when I get home from work. http://forums.pelicanparts.com/uploa...1643210120.jpg
derm.1785 01-26-2022 07:16 AM
Here you go. They measure 98mm diameter, no other markings that I can see.
john walker's workshop 01-26-2022 01:17 PM
Complete cylinder pic from the top would tell us more. hopefully bored 3.2 carreras without the sealing ring groove.
derm.1785 01-26-2022 02:02 PM
http://forums.pelicanparts.com/uploa...1643234347.jpg
derm.1785 01-26-2022 02:03 PM
They don’t look like they have been bored out, too thick still
RobFrost 01-26-2022 10:18 PM
98mm 3.2 Nikasil cylinder 1974-1979/80. Mahle documentstion was poor in this period. I believe some 95 designated cylinders were actually made 98mm for the 3.2 engine.
It may be the ++ is the key part of the designation indicating they're 98mm / 3.2 cylinders.
If your German is ok there is a little more info here. http://elferszene.de/showthread.php?t=23781
Sent from my SM-G988B using Tapatalk
derm.1785 01-26-2022 11:08 PM
If your German is ok there is a little more info here. Bezeichnung an den Mahle Zylindern beim 3,0 SC - Elfertreff - Das 911 & Porsche Forum
Thanks for the link, it’s an interesting read and gives me an indication of what I have. I love the idea that the factory built engines based on random shelf picking of core components.
Schulisco 01-27-2022 04:58 AM
Translation with Google Translator:
https://elferszene-de.translate.goog/showthread.php?t=23781&_x_tr_sch=http&_x_tr_sl=de& _x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
Flat6pac 01-27-2022 01:55 PM
Turbo, 97mm, are based on the 95N1, etc
98 mm are opened for 3.4.
Bruce
