Question What is Behind the Rocker Skin Near Jack Plate?
It looks like I am going to have to cut away some perfectly good skin to get to what may be behind it requiring rust repair. I do not want to cut off any more than I have to to access the damage. But I cannot find any images of what the inner rocker looks like with all of its braces under the skin. I have some idea, there is some rust. And a lot of dirt, I started on the car without power washing it, too late now.
I want to be sure I do not cut too deeply and damage good metal behind the skin making more work for myself. There is a little triangular looking brace that connects the bottom of the skin to the inner rocker, next to the jacking tube plate and the vertical reinforcement. Can anyone post a photo of what this area looks like, not rusted, and without the skin? In a side view? Is the vertical brace supposed to be open at the bottom? What does this area look like underneath the external sheet metal?
The wife is at her mothers for the day so I took the day off work tomorrow to dive in here and get something done. Even a view without skin and a surface rusty but intact underneath bits will be most helpful.
TIA!
Triplesn8s
'72 911T Coupe - Resto Proceeding at a Snails Pace
‘80 TR8 Convert - SOLD
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS - ‘11 H-D XR1200x
Old 01-27-2022, 07:47 PM
Uncertifiable!!!
Uwon's Avatar
Go to the Restoration-Design web site to get a full picture of all the bits and pieces.
Good luck.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-28-2022, 05:38 AM
digitaldgp's Avatar
When I had my rockers replaced.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 01-28-2022, 06:53 AM
Thanks guys. Those are some good photos. I think I figured it out. Looking at my first photo i think I see a spot weld & that extra angled piece (yellow dot) was welded to the exterior skin tying it to the inner rocker. The replacement pieces incorporate that tie-in into the rear of the exterior rocker panel (red dot). At least that is what I th9ink I am seeing. Or not...?
Triplesn8s
Old 01-28-2022, 07:13 AM
Hey digitaldgp,
What is the pink stuff in your photos?
Triplesn8s
Old 01-28-2022, 02:39 PM
Question What is the pink stuff in your photos?
Hey digitaldgp,
What is the pink stuff in your photos? Some sort of electrically conductive sealant?
TIA!
Triplesn8s
Old 01-29-2022, 06:03 AM
digitaldgp's Avatar
triplesn8s,
DG Vintage Coach Works, did all the metal restoration.
I believe it is a conductive coating for the welding of the panels.
As they applied it to the rocker side as well before the spot welding was completed on them.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
Old 01-29-2022, 07:53 AM
Work in Progress
Rich76_911s's Avatar
A member has done a pretty thorough write-up on this repair with photos. You can see his work here:
Home Page - DarrylD's Porsche 912 Project Rust Repair Pages
Left longitudinal: DarrylD's Porsche 912 Project Page - Phase 3: Left Longitudinal Channel Repair
Left outer Rocker: DarrylD's Porsche 912 Project Page - Phase 4: Left Outer Rocker Panel Replacement
Right Longitudinal - DarrylD's Porsche 912 Project Page - Phase 8: Right Longitudinal Channel Repair
Right outer rocker - DarrylD's Porsche 912 Project Page - Phase 10: Right Outer Rocker Panel Replacement
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 01-30-2022, 04:29 AM
Thanks Rich, That is very helpful. Still looking for the brand name of the conductive paste. I want to try it out.
Triplesn8s
Old 01-30-2022, 07:07 AM
It looks like DG VINTAGE RESTORATIONS, LLC went out of business a couple of years ago.
https://opencorporates.com/companies/us_wa/604081896
Triplesn8s
Old 01-30-2022, 07:14 AM
digitaldgp's Avatar
DG Vintage Coach Works.
He is still in Business. In Sultan WA.
DANNYVWS@GMAIL.COM
https://www.instagram.com/dgvintagecoachworks/
https://www.facebook.com/profile.php?id=100008290953658
https://forums.pelicanparts.com/porsche-911-technical-forum/1079693-body-shop-seattle-area.html
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
Old 01-30-2022, 07:59 AM
digitaldgp's Avatar
Danny told me it is weld thru primer, they spray it in a cap and then brush it on. Made by Wesco.
Dave
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
Old 01-30-2022, 09:24 AM
Thanks. found it. Wonder if it is any better than the spray on zinc.
https://buy.wesco.com/static/catalog/products/images/PDF/K00532910-16.pdf
Triplesn8s
Old 01-31-2022, 02:53 PM
