Grappler
Rodsrsr's Avatar
Its almost ready...again
Pulled the motor last year for a rebuild and will give updates and details once the engine is back in the next few weeks. In the meantime I cleaned up tons of loose ends on the car and prepped all the ancillary components for reinstallation.
Motor is currently out for new rings (all pistons/cylinders well within spec) new rod bearings, ARP rod bolts, and steel head studs. Heads were recently done with web grind 20/21 cams, new valve seals, and new valves.
In the meantime I've cleaned up the engine bay, replaced fuel lines, all main electrical harness (from DME) new fan, enlarged throttle body, serviced injectors, new Clewett ignition wires, Wevo shifter, among several other projects. I even got a chance to clean up the interior a bit and detail the exterior. Looking forward to getting it back on the road before summer.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 05-01-2021, 06:26 PM
Grappler
Rodsrsr's Avatar
Its a turbo 3.2 running at .5 bar with a Rarlyl8 Outlaw muffler.
Grappler
Know Gi / No Gi
Old 05-01-2021, 06:28 PM
That’s a beauty!! I bet it will breathe fire once you get it in and it’s dialed
1977 911S(c) with an 81 SC engine Anthrazite grey metallic
1979 911SC Coupe in Sky Blue - SOLD
1976 911S Widebody Targa - SOLD
Old 05-01-2021, 09:08 PM
Dr J's Avatar
Rodsrs, I always look forward to your projects. They are neat.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 05-02-2021, 05:01 AM
Grappler
Rodsrsr's Avatar
Thank you gentlemen!
Grappler
Know Gi / No Gi
Old 05-02-2021, 08:00 AM
Grappler
Rodsrsr's Avatar
Its amazing how many things you choose to tackle while you have the time. That's probably the only blessing in waiting for the engine to be completed. I've basically fixed all of the items I've put off for the past several years.
Backup lights fixed.
E-brake fixed, (simple fix if anyone else is experiencing a non functioning e-brake)
gauges restored. (shout out to pelican Jbell)
new injector harness
new fuel lines
Injectors serviced (witchunter)
new fan.
all engine bay wiring new.
RSR engine brace
Wevo shifter
body to bumper seals
Wevo sideplate with 930 bearing for 915 gearbox
Factory LSD
Bumper to body seals make a substantial difference
Front body seals are a serious pain to line up correctly but details make the difference.
Next time you see her, she'll be sitting in a proper stance!
Grappler
Know Gi / No Gi
Old 06-07-2021, 07:51 PM
rokemester's Avatar
Your car looks BADASS! Can’t wait to see it on the road.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 06-08-2021, 02:48 PM
We're excited for you to get the engine back in! That paint is gorgeous.
Definitely a top notch rebuild, wish I had the resources to do a similar refresh on my 84 BMW
Old 06-08-2021, 02:58 PM
Grappler
Rodsrsr's Avatar
Thank you! Its been down for too long, but some things (like an air cooled flat 6) you just cant rush.
Grappler
Know Gi / No Gi
Old 06-08-2021, 06:14 PM
Beautiful just beautiful.
Old 06-09-2021, 06:57 AM
Beautiful...and therapeutic. Would love to see a pic of the engine just before install.
1986 3.2 Carrera
Old 06-09-2021, 07:35 PM
Grappler
Rodsrsr's Avatar
long overdue update....While the engine is out I decided to tackle a few other projects I've been wanting to do. First off, I decided to put heat back in the car. Adding heat will allow me to drive it year round. Because all of the blower components were previously removed, I opted for a simple backdate heat system with heat going directly from the footwell outlet to the defroster. (with a small vent in-between to allow heat in the cabin)
This is untested but I think it will provide enough heat to work sufficiently for Nor Cal winters which are not too bad.
I also updated the door panels with some inspiration from another Pelican and as you can see the heat ducts are not visible unless you really stick your head under the dash.
The motor is finally ready and I'll be picking it up later this week. Surprisingly the original rod bearings were actually in extremely good condition considering the mileage. Below is a pic of one of the original Porsche red bearings dated 1984. We went ahead and installed all new rod bearings along with ARP rod bolts, reconditioned the rods, new steel head studs. New rings, valve job, 20/21 cams, new clutch, and all new seals. I'll post engine pics soon.
Grappler
Know Gi / No Gi
Old 09-13-2021, 05:47 PM
Grappler
Rodsrsr's Avatar
Finally got the long block back!
915 Gearbox with Wevo reinforced side cover.
Waiting on a few small parts to install the induction system and ancillary components.
Grappler
Know Gi / No Gi
Old 09-22-2021, 04:43 PM
Grappler
Rodsrsr's Avatar
Got a chance to work on it today. clutch assembly installed.
Ready to install intake...nice fresh valves.
Intake, fan assembly, ign wires, etc...
Gearbox mated to engine.
Front engine brace installed...
Grappler
Know Gi / No Gi
Old 09-23-2021, 10:10 PM
Grappler
Rodsrsr's Avatar
Grappler
Know Gi / No Gi
Old 09-23-2021, 10:15 PM
Grappler
Rodsrsr's Avatar
Tons of work done the past few days.... Almost ready to start. Gas and oil in, most everything is buttoned up, went to start and a completely dead battery. Charged overnight and only 10 volts this morning.
Engine install.
CV joints reattached
all other ancillary components installed.
Still need: Clutch adjustment. misc hose (for MAF) reinstall decklid hinges, new battery.
Grappler
Know Gi / No Gi
Old 10-02-2021, 05:44 PM
Grappler
Rodsrsr's Avatar
Grappler
Know Gi / No Gi
Old 10-02-2021, 05:51 PM
Beautiful car . How are you passing ca smog with a turbo set up in a 76?
Old 10-02-2021, 06:07 PM
Grappler
Rodsrsr's Avatar
Thank you! I've owned the car before that 76 law was passed, and I now live in an area that doesn't require bi-annual smog inspections.
Grappler
Know Gi / No Gi
Old 10-03-2021, 09:54 AM
7.0:1 > 11.3:1 > 7.0:1
How many months has your car been down? It looks like you were quite productive.
Old 10-03-2021, 04:58 PM
