alf alf is offline
alf's Avatar
New Oil Fan Thermostat switch from Pelican not working...
Installed the 99 C thermostat switch i bought from Pelican yesterday, it was quite a pain to install, had to remove the oil cooler to do it. Not a big deal, except it does not work . I got the temp to 9 o'clock and still no fan kicking in...
One end connected to the wire that came on the OEM thermostat, the other to the ground on the radiatior.
Called Pelican for tech support, but the guy on the phone was no help.
Anyway greatly apprecite it if anyone has any hints for trouble shoothing this thing.
thanks
alf
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 05-19-2003, 02:14 PM
Use a multi-meter to see if the switch kicks off at proper temperature. Sure you're hitting the temp?
Warren & Ron, may you rest in Peace.
Old 05-19-2003, 02:17 PM
alf alf is offline
alf's Avatar
99C is 210F. I think 9'oclock on the guage should be about 225F, so the fan should be on...unless my temp sender unit is off.
alf
88 Carrera Coupe
Pelican Since 2002
The Roach
Old 05-19-2003, 03:03 PM
Early_S_Man's Avatar
Porsche Crest
Test the switch in a pan of cooking oil on a hot plate ... make sure the contacts close by an indicated 225 ° F on a meat thermometer, or thermocouple probe on a DMM/thermometer.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-19-2003, 05:23 PM
