| View Poll Results: Where should I place the lift? | |||
| A |
2 | 28.57% |
| B |
0 | 0% |
| C |
1 | 14.29% |
| D |
2 | 28.57% |
| E |
1 | 14.29% |
| F |
1 | 14.29% |
| Other - Please Specify |
0 | 0% |
| Voters: 7. This poll is closed | |||
LinkBack | Thread Tools | Rate Thread |
Lift Question - Placement
Ok, now I need to figure out where I'm going to place the lift in the new shop. The hole for the lift will be created when the foundation goes in. I'll make a cover for it, so it will be flush and out of the way when not in use
I'm 99.99% sold on the Mohawk Lift More on that decision here: Scissor Lift Summary
After enumerating my choices, "A" seems to be a better choice than I'd originally imagined. For reference, the structure is 25'x25', with 10' walls and the ceiling will be ~13' in the center. I'm always open to suggestions. Also, the lift guy is supposed to be bringing a demo unit out tomorrow after work. If anyone wants to come by and check it out, lemme know.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
one of gods prototypes
i would go with "A".
this will leave you a large open space should you need it. so far the poll is 100% for A LOL
Brought to you by Carl's Jr. |
my 2 cents....i vote for D....
when you pull your engine and tranny you can put that in the A/B region near your bench and work on it there... at A, I would imagine the car would then be between your bench and the engine tranny MJ |
Somewhere in the Midwest
Between A and B! I have about 3' between my lift and the carbinet/wall, and it is a pain sometimes. Give yourself at least 4 feet, but 5 is better...workspace makes a job much more enjoyable, but cram into a corner while turning that srew upside down under the flapper box with your leg sticking up in the air sucks!
Platinum Member
E or between E and the garage door. You won't need to move other cars/stuff to get to the lift, and if a project ties up the lift, you can still park under it.
Never mind, can't park under mohawk. Why not get afull height lift?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
