where to send 3.2 crank for reconditioning
I have a 3.2 crank that needs to reconditioned. Spun the #4 rod bearing and the journal is out of round, out of spec. Needs to be reground, nitrided, polished etc.
Who would you recommend to do this work? regards, al PS: I do have some good sources, but would like to research the alternatives, based on your experience |
I would suggest posting that same question in the engine forum.
Hey Al
https://winbergcrankshafts.com/ This is where I send my cranks , they are in a class by themselves Ian |
Hey Al, I typically use Marine Crankshafts in Orange CA but they currently have a 2-3 month backlog. So if you're in a hurry that doesn't work. This is the shop Henry Schmidt uses and also who makes his custom Supercranks
Engine Component & Machine in Santa Ana CA has been around forever.
| All times are GMT -8. The time now is 08:05 PM. |
