Full Send Society
Painting over rubberized coating help
Hello ladies and gentlemen,
I'm in the process of painting some things and have run into a bit of a sticky situation...
It seems that every paint I use over the rubberized coating on the gas tank and inside the trunk leaves it sticky and simply won't dry. I've tries several types of aerosol paint (lacquer, enamel, polyurethane...) and no luck; a sticky mess even after 72 hours.
I haven't tried 2k paint yet but suspect that will yield the same results.
I don't want to strip the coating off the tank- just repaint it because it's fugly.
Water-based primer and then the topcoat?
So I'm looking for any advice from anyone who has found a solution.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 02-15-2022, 06:48 AM
Pedro '84 Coupe's Avatar
After coating my new tank with Wurth undercoating spray, I was able to paint the coating with a Rustoleum or Krylon rattle can - can't remember the color name. Came out not bad considering I'm a terrible painter. Is the coating you used able to be painted? Maybe it's too cold for the paint to dry properly?
2000 Boxster S and 2016 Audi A6
Old 02-15-2022, 07:21 AM
Flojo's Avatar
what solvents are in the paint you use.
some ingredients kind of "reactivate" the rubber and it gets soft, thus coating not drying
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-15-2022, 07:40 AM
Full Send Society
For sure the solvents in the aerosol spray paint are the issue. The problem is that all spray paints contain acetone and xylene (not to mention a billion other solvents) that attack the rubber.
I've tried Rustoleum, VHT and Wurth ruberized undercoating and all of them leave a sticky mess.
I can get acrylic spray paint and try that as a base coat... I suppose that's the next step.
-Julian
Old 02-15-2022, 08:03 AM
Earthling
Brian Cameron's Avatar
You might want to trying posting this question over on the Paint & Bodywork forum, with luck user 962porsche may chime in, very knowledgeable guy. Hope you get it sorted
https://forums.pelicanparts.com/paint-bodywork-detailing-forum/
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 02-15-2022, 08:53 PM
