Sway bar Blues
Guys, any advice or secrets to getting my front sway bar back in? I have been struggling with it for a few hours now and have run out of ideas and techniques.
Based on a possibly faulty memory, I recall that you have to take one A-arm off to replace the swaybar bushings. So I think you need to start with the two interior bushings on the bar, and the other two in the A-arms. Put one end of the bar through the bushing on the A-arm that is installed. The other end goes in the loose A-arm. Soapy water in the bushings makes things slide together easier as you raise the loose A-arm into place. I used the OEM rubber bushings, and I remember it being a wrestling match; stiffer ones may make it harder yet. —Dave
1985 Carrera 3.2 • Prussian Blue Metallic |
Functionista
You will notice when the car is jacked off the ground the suspension is in droop, the two brackets on suspension being closer together. Helps to have a lift and a pole jack or two to support one or both so they are spread apart some.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Dang it, really? If I were only just twice as strong!
so lifting a side will get me closer?
Functionista
On the smaller bars you can generally muscle them in with a long pry bar. The 22mm 930 bar in my car required some more effort.
Functionista
No dice. Compressing/lifting the A-arm does change the geometry, unfortunately.
Functionista
I recalled pole jacking both sides using a ratchet strap on one side to pull front of car down some. The front of these cars is fairly light and will come up before a-arm is level sometimes. Even then it was a struggle with a giant pry bar. Using soap or some lube helps.
Crap, it shot the bushing across the floor when it went in.
I think I am done for the day. I still have to get it out before I try again.
No joke, I went with a through body sway bar partially because I didn't want to ever have to deal with this.
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Location: behind the redwood curtain, (humboldt county) california
Inserting the bar :-)
I had just rebuilt the front suspension, Elephant bushings, ball joints and blasting/Por-15 painting everything. It was out on the bench.
I installed the new 20 mm bar bushings in the arms and liberally lubed the interior of the bushings with sillykone/ruber lube. I next inserted one end of the bar into a bushing, pushing it in further than it needed to go, so that the end of the other side was as close to alignment as possible. I next used nylon tiedown rope to rig a truckers hitch to pull the bar into position to get the end installed into the other A arm bushing and i could slide it right in, then shift it back and forth to allow the chassis mounts to align. The A arms were in full droop, the thing that really made the bar installation possible was the silicone lube, pushing the bar further into one side than needed and using a rope/hitch to horse the other end of the bar into aiignment for insertion. As usual, inserting the bar is vastly gratifying, particularly after the usual wrestling and strong language - don't forget the lube :-) |
Through the body...
Additionally, you have the option of installing adjustable length "arms" on the bar, as well as adjustable drop links, to dial out the preload - where-as, the undermount bars are non adjustable in either dimension. chris |
Another one of PAG's cost-cutting strategies. Yes, I would be tempted to find a pre-owned Weltmeister or equiv. through the body sway bar. The factory undermount sway bar seems more like what GM, Ford or Chrysler would produce, except their sway bar attachments don't suck as much.
Sherwood |
FWIW, the Eibach front bar design incorporates separate links that bolt into the control arm sway bar bushings.
https://www.instagram.com/p/B5nbTwxlUKY/?utm_medium=copy_link
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
