Ferrino's Avatar
Charcoal Canister
I've done a lot of searching on the fuel vapor canister but haven't been able to find opinions on the longevity of these items: do they "go bad" after prolonged use? e.g. can they get blocked or does the charcoal need to be replaced? I seem to remember the Bentley manual calls for replacing after a certain number of miles.
Presumably charcoal canisters for various vehicles are pretty universal - maybe there is a cheap one from another car that could be used?
Old 03-31-2014, 05:15 PM
SchnellSchweitz's Avatar
I believe you can open the canister and replace the contents with fresh charcoal. Takes a little ingenuity to open it, but I've read on this forum where people have done it.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 03-31-2014, 05:43 PM
AutoBahned
RWebb's Avatar
the canister is good until it blows up or gets raw gas inside - no need to replace or refill
Old 03-31-2014, 07:18 PM
Carbon cannister....
You could pry it open and remove the old carbon pellets. Replacing the old carbon pellets with fresh one would be a prudent course of action. The carbon (pellets) works as a filtering media for the toxic vapor or fumes generated from the gasoline in the fuel tank.
Tony
Old 03-31-2014, 07:52 PM
on my 82sc i was going to ditch it to save weight but letting raw fumes collect in the intake seemed like a bad idea especially if theres a backfire at startup. plus its pretty light. When i got it off i saw that the cover was nearly pushed off. so it had a huge air leak and wasnt doing much anyway. Luckily nothing came out but the spring inside was way too strong. so i used some wire to tie up a few coils and silicone sealed it back together. So yeah pull it apart and see what you have there. Id say if its still full of media your alright. Its self cleaning im not sure if it really goes bad
Old 03-31-2014, 07:59 PM
Bye, Bye.
Scooter's Avatar
Ferrino, do you need a canister?
Elvis has left the building.
Old 03-31-2014, 08:16 PM
AutoBahned
RWebb's Avatar
"The carbon (pellets) works as a filtering media for the toxic vapor or fumes generated from the gasoline in the fuel tank."
Yes, I would say as an absorbent tho, not as a filter.
However, the activated carbon will continue to do its job for many decades if not centuries and there is no need to replace it unless contaminated with liquid gasoline.
Old 03-31-2014, 09:08 PM
Ferrino's Avatar
No, I have an original one from 1976, thanks. Just wondering if it should be replaced or refreshed somehow.
Old 04-01-2014, 12:24 AM
Open it and see if anything is left inside.
I have a 1971 Corvette. Removed the vapor can. It was a hollow shell. An empty can. Doing nothing but providing hook-ups for vacuum lines.
You can "Recharge" the can with activated charcoal from an aquarium supply place and reseal.
The Corvette has no can now. I did save the can, though.
BTW, the raw gas smell so common on this vintage of Corvettes is GONE without the can. My friend's '74 stinks the high heaven.
Carter
Old 04-01-2014, 05:55 AM
My canister was blown apart when I got the car, the pellets were everywhere. I would like to replace it but really haven't found anywhere that carries them for an 86 3.2 It appears Pelican MIGHT, it is listed in the correct section but the notes state the applications are only 944 and 928. I would like to replace it as I heard that without it can cause vacuum leaks, not sure how true that is but just to help with gas smell would be worth a few bucks. If anyone knows where to attain one that would be great. Sorry of this seems like a hijack, there are just so few posts related to the charcoal canister
Old 04-01-2014, 06:05 AM
The part pelican carries is indeed the correct part, FYI and mine
Old 04-01-2014, 06:25 AM
Bye, Bye.
Scooter's Avatar
Gemballa 2006,
I have one off my '87 that I removed. You want it, it's yours. Consider it a a pay-it-forward type thing.
I just ask that you pay for the shipping.
Old 04-01-2014, 07:15 AM
Hunt3R's Avatar
If Gemballa doesnt want it Id gladly pay you for it. I had to remove mine because the filter inside of it disintegrated and the pellets leaked into the hoses and clogged them.
Old 04-01-2014, 08:46 AM
Ferrino's Avatar
Thanks, I may crack it open and take a peek. I don't see why a new one from a more modern car would not work though?
Old 04-01-2014, 10:18 AM
AutoBahned
RWebb's Avatar
one from a different car will work fine if connected properly
Old 04-01-2014, 12:03 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Gemballa 2006,
It would be cheap if delivered to the UPS store in Ogdensburg New York.
Who Will Live... Will See
Old 04-01-2014, 03:45 PM
Ferrino's Avatar
Can anyone with a Carrera please confirm the location of the charcoal canister? Am I right in thinking that in the Carrera it moved from within the engine bay (just in front of the oil tank filler) to inside the passenger rear quarter?
Old 04-16-2014, 10:40 AM
Bye, Bye.
Scooter's Avatar
Inside passenger rear fender. Not in engine bay. Above the wheel, closest point to the door jamb.
Old 04-16-2014, 10:44 AM
Flojo's Avatar
a part to get rid of.
I did.
Old 04-16-2014, 11:08 AM
Ferrino's Avatar
Thanks very much! Thinking of moving it there to clean up the engine bay a little. Bit concerned about the fresh air intake port on the canister getting plugged from dirt though - is there a hose on that port which draws air in from the engine bay instead?
Old 04-16-2014, 11:17 AM
