Classic Retrofit Install Question - Webasto?
For those of you that have installed the Classic Retrofit Electro-cooler AC system in the USA, the instructions say that we need to buy 60 and 40 mm air ducting.
"60mm / 40mm air ducting (we recommend genuine Webasto aluminium/paper hose)" Where the heck did you get the 40mm hoses (and 60mm for that matter)? Everything I see that is 40mm is from overseas and shipping is slow and expensive. Best Regards, Eric |
Hey everyone, Jonny pointed me to the pelican parts versions of these. Thanks!
911 573 204 00 40x1000mm 911 211 522 01 60x1110mm |
I used some of this
CAT-10 DUCTING 2 1/2" 4FT - for the 60mm https://www.aircraftspruce.com/catalog/pnpages/05-29810-4.php |
Thanks Nditiz1!
Also for the 42mm I purchased it off of Amazon
https://www.amazon.com/gp/product/B08LYK8GL3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 |
1.5” ducting will work too for the 40mm. It’s tight but it does fit over the fittings.
| All times are GMT -8. The time now is 09:54 PM. |
