Another potential air leak location
Just one more place to look for hidden air leaks/idle issues. Discovered this little gem while changing out a blown airbox. Its the rear side of the throttle bypass screw (idle adjuster) on the rear of the throttle body.
I honestly dont know how this happened. It has never been dropped or damaged in any way that i know of. The worst part of it is that you’d never see it unless you were specifically looking for that crack. Its buried in the back of the throttle body behind the brass vacuum tube for the brake booster.The only reason i found it was i was cleaning the TB and the rag kept snagging on the crack.
I’m going to JB Weld it, hopefully that will fix it. Any comments/suggestions welcome
Old 02-25-2022, 07:31 AM
Looks like that screw was bottomed out well past bottom at some point in time
Old 02-25-2022, 07:33 AM
No *****, thank you for posting and the pictures..one more spot for me to check. And one more for you, Put a little AT-203 on the injector O rings that are old and installed, wait an hour and drive until warmed up, if your idle slows down the O rings are leaking.
I'm not picking my nose..I'm porting my upper intake manifold.
Old 02-25-2022, 02:44 PM
Originally Posted by jbs3 View Post
............. Its buried in the back of the throttle body behind the brass vacuum tube for the brake booster.
The brake booster hose is much larger than that brass tube on my car, I might have a larger tube than that my 1977 if that's possible. I'll have to check, one of the last hoses I still have to change out. My hose frayed at the bottom under the transmission and I patched it with some goo.
What year car is yours?
Old 02-25-2022, 02:53 PM
