-   -   Help with Part # (http://forums.pelicanparts.com/porsche-911-technical-forum/1113496-help-part.html)
fiskarflugen 02-25-2022 04:31 PM
Help with Part #
Does anyone know what the part # is for the bracket that holds the Beru wires on the passenger side of the engine??? PET shows the drivers side but not the passenger side.
Thanks!!SmileWavy
proporsche 02-25-2022 11:59 PM
1st you have to mention what 911 it is for and even show the pet picture to be helped
to insert a picture "go advanced "and there is a blue line to be used for pics
Ivan
fiskarflugen 02-26-2022 07:20 AM
I appreciate the guidance. To be clear, the issue is that I cannot find it in the PET for my 1984 911 3.2. Its the two ignition wire brackets on the passenger side and the little bracket that holds the thermostat wire on the shroud that I am looking for.http://forums.pelicanparts.com/uploa...1645888732.jpghttp://forums.pelicanparts.com/uploa...1645888811.jpg
proporsche 02-26-2022 08:21 AM
well the answer is simple.Only 1984 spark plug wires were routed around the 4 5 intake manifold.Therefore no little bracket were used..looks like this
[IMG]https://www.autorevue.cz/GetFile.aspx?id_file=142413943[/IMG]
Ivan
fiskarflugen 02-26-2022 08:27 AM
Thanks Ivan! Much appreciated
