Difficult case of no spark. Experts wanted!
Yesterday I created a post about an ignition problem I am having. Thank you for all those who commented. I have now run all the tests I know of and still cannot find the culprit. I have a 71 911T with Zenith Carbs and a Marelli distributor. It underwent a complete restoration in the late 90’s and recently came out of a 3.5-year hibernation. After some initial work rebuilding the carbs and getting the some the brake work done, it ran great for a few days. Then the CDI unit went bad, had it rebuilt, and again ran great until 2 days ago. After a 10 mile trip I went to restart it after lunch and it wouldn’t fire up. The engine would turn over fine. Waited 20 minutes same thing. Had it towed home and pulled off the fuel line and the pump was pushing plenty of fuel. Checked for spark and nothing.
I pulled off the distributor cap and when I toggle the advance the points are opening and closing. I also ran some fine grit sandpaper gently over them just to make sure they were clean. I read 12 V at the center plug on the CDI with the ignition on. I performed the telegraph test-> no spark. I put a spark tester in the coil high tension lead and cranked the engine-> no spark I pulled a plug wire and put the spark tester in the plug wire and cranked the engine-> no spark. I initially thought it was the coil or the CDI unit. I recently had the CDI unit rebuilt by Bob Ashlock. He bench tested the CDI unit (including heating it up and running it hard) and the coil and they were both good. I even borrowed another good CDI unit just to make sure and still no spark. I then checked the continuity of the wire between the C pin on the plug and the distributer and it was good. Likewise the continuity from the A pin to the coil was good. Bob also said to check the voltage at the C pin wire at its connection to the distributor. He said with the key on there should be 12 V going from the C terminal wire on the CDI to the distributor. I pulled the C wire from the distributor and put the key in the on position and no voltage at the end going to the distributor. So 12 V at the B terminal of the CDI plug but nothing at the end of the C wire. In addition, I have cleaned, sanded, and placed dielectric gel on all the grounds and checked every connection I can see. I have included a shot of my wiring near the CDI. There are 3 loose female ends (2 coming out the same clump of wires) but I believe these have always been unconnected. The ground to the back of the CDI (bare ground) is connected to the ground in back of the plate that the CDI and other relays are mounted onto. I know that is a lot of information but I am hoping someone can lead me down the right path. Thanks in advance, Jeremyhttp://forums.pelicanparts.com/uploa...1645918042.jpg |
I see the 2 pole fuel pump wiring connector, the MFI fuel enrichment wire, the rear defrost and the license plate wiring in your photo.
Looks like the CDI wires are tucked under the CDI unit? Have you checked the fuse for the CDI wire in the front? And why start a new thread? |
i.e. unless the battery is jumped incorrectly. Furthermore, why hasn't your CDI "rebuilder" continued to help you to solve your problem? Since you spent money, potentially unnecessarily, he should spend the time to help you resolve your problem, e.g. most who rebuild CDIs will do that. Once the "C" wire is disconnected from the distributor and the tach wire is removed , it should measure about the battery voltage (12V). |
Take a look at the wire going into fuse 8 top stack headlamp side. It is unfused, but only sees power from a jumper on the back of the fuse block from fuse 7.
Coil: Measure the resistance/continuity between the two outer terminals on the coil and between each of the outer terminals and the high tension tower in the middle of the coil. Report findings. Per the Porsche Factory manual the CDI puts out about 400v. The coil Primary resistance should be 0.4 to 0.6 ohms, and the secondary is 650 to 790 ohms. Check continuity of the wire between the points and the plug that connects to the CDI. Center is power. On one side is the wire to the points and on the other is the wire to the coil. Report findings. ... until this is addressed the rest of the tests are meaningless. |
1. The "C" wire is still shorted to ground. 2. There's an internal problem in the CDI. You need to power-up the CDI out of the car and measure the "C" pin of the CDI. Quote:
You need to disconnect the CDI from its connector and measure terminal "C" with a meter to ground (CDI case) for continuity, key-off. Then measure the "C" pin (ohms), with the CDI disconnected, to ground (CDI case). Did your rebuilder ever indicate the failure mode of your CDI? By the way, where are you located? |
Just so I am straight on the terminology, when you say "terminal C" do you mean the plug side that connects into "pin C" on the CDI unit itself? Is that correct? So the first test you suggested, "You need to power-up the CDI out of the car and measure the "C" pin of the CDI." Can I place an alligator clip from the B terminal on the plug to the B pin on the CDI unit to give it power and then measure the volts at the C pin on the CDI unit? I am assuming that the C pin should measure 12 volts. For the second test, "You need to disconnect the CDI from its connector and measure terminal "C" with a meter to ground (CDI case) for continuity, key-off". After pulling the plug off the CDI and with the key off, I would measure for continuity from the C terminal (plug side) to the CDI case. Then with the key still off, measure the resistance (ohms) from the C pin on the CDI unit to ground, in this case the CDI case. When I measure to ground on the CDI case, are you referring to the ground pin on the CDI unit in front of the A, B, and C pins or anywhere on the case itself? I am assuming the case acts as a ground. Sorry about all the questions. I am a little new with all the terminology and I want to make sure I am testing correctly. Could I check the individual wires from the CDI to the coil and distributor by bypassing them with alligator clips. For example, I connect a clip from the B plug (power source) to the B pin (CDI unit). Then I place alligator clip from the C pin (CDI unit) to the connection on the distributor (on the common connection with the tach wire). Another alligator clip from the A pin (CDI unit) to the coil. Another clip could ground the CDI unit. If the car runs I know I have a bad C or A wire and the CDI is ok. Then it is just a process of putting one of the wires in question back in the circuit to find the bad one. If it still doesn't spark after bypassing the B and C wires it would tell us that the CDI unit is bad. Is my reasoning sound or am I missing something? I live just a mile down the road in Laguna Beach, do you make house calls? Thanks, Jeremy |
of the Quote:
Given that, your original problem still exists. |
1. The B terminal on the plug measures 12 V with the ignition on. However, when I connect the B terminal on the plug with the B pin on the CDI via an alligator clip, the voltage on the B pin goes to <1 V and the C pin reads < 1 V. If I connect the B pin on the CDI directly to the battery the C pin reads 12 V. I think this is where the problem may lie. When the CDI unit is plugged into its connector, the voltage drops to <1. 2. When I check the continuity between the C terminal on the plug to it's connection to the distributor, it reads <1 ohm. Looks like the C wire to the distributor is ok?? 3. When I measure terminal C to ground on the CDI case, it measure 1-10 ohms depending where I ground on the case. 4. I also checked the continuity of the coil and everything is within spec. Looks like we may be narrowing it down. What do you think could be going on? Thanks, Jeremy |
I just posted the results from the tests I ran. Any thoughts? |
Before troubleshooting the power problem, use a jumper wire to power the B pin by connecting the wire to one of the fuses on the left side near the big engine harness connector. Hopefully, your engine should start. |
| All times are GMT -8. The time now is 03:05 PM. |
