Oil Sump Stud - ‘73 911E
Had a stud pull free while reinstalling the sump cover ‘73 911E. My torque wrench was set at 8ft/lbs, so I was surprised when it kept spinning. I did notice some silver in the case-side threads that maybe old helicoil?
I also have 1 to 2 other studs that may be spinning. Some other posts made it sound like these studs spinning is somewhat common and to just reinstall/replace and add red locktite. Others suggest tapping and using a new m6x1.00 helicoil. Thanks for any help! |
The magnesium cases are indeed soft. Personally, I would use a helicoil. The red loctite alone may, work but I like to have threads when using threadlocker. I might also go with blue loctite after the helicoil, just in case I ever had to remove the studs. Red is very strong.
Ed 1973.5 T |
(man/dude)
A torque spec like that assumes a dry fastener. If its oiled it would affect the torque spec by 30-40% (according to 30 seconds of googling) and that would be enough to pull from a mag case.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Timesert. Tighten by hand, with discretion.
Timesert look like a great option, thanks John!
Interesting point too about the dry/lubed torque too. 8ft./lbs to 10 or 11ft./lbs doesn’t sound like a lot, but it is a mag case. Thanks all! |
Thanks, Sully.
