Matthew_VA's Avatar
Looking for 911sc door cards (eBay?)
Looking for new door cards/panels to upholster (don't really want to destroy existing ones). I saw these one ebay, which look pretty good. Anyone bought a pair or does anyone know of a domestic source? not having much luck with my search...
TBD
Prior: '84 911 3.2 Carrera, '83 911SC Targa
IG: @heuersandcarreras
"I want to use it. That's what 911s are for." - Richard Hammond
Old 03-01-2022, 07:31 AM
My door cards are water damaged and warped so also looking for a replacement solution. Was going to make a set from home depot hardboard but the item you posted looks like its a better option, and seller claims its the correct thickness material. Downside is shipping from overseas...
Another Ebay seller has aluminum replacement door cards touting the advantage that they won't warp, but how do you attach the vinyl/leather skins to aluminum? I doubt staples would work
https://www.ebay.com/itm/273770903435?_trkparms=amclksrc%3DITM%26aid%3D1110 01%26algo%3DREC.SEED%26ao%3D1%26asc%3D201609081050 57%26meid%3D5809ed797e5d4be79285c16d0a681671%26pid %3D100675%26rk%3D4%26rkt%3D15%26sd%3D174124240538% 26itm%3D273770903435%26pmt%3D1%26noa%3D1%26pg%3D23 80057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A8d14684a-9979-11ec-bf40-daa84b74a415%7Cparentrq%3A463ba2c717f0a9b12e7b6863 fff7a865%7Ciid%3A1
'80 911sc Turbo Look, Sienna Metallic
Old 03-01-2022, 08:34 AM
80-911SC's Avatar
Most would use glue and clamps until it dries
They are around or you can cut out of plastic that’s like yard sign (election type stuff) material
You can staple to it easily
Old 03-03-2022, 09:21 AM
