Anybody ever take the clock apart?
My clock doesn't work. I have a different one but all my gauges have red faces to mach the car. I need to take the red face out of the bad one and install in the new one. Can this be done? Any help?
75/81 3.0 Slant Nose Cab
SSI/M&K/3.2 intake Megasquirt
Old 04-16-2007, 10:17 AM
I meant (Match)
Old 04-16-2007, 10:18 AM
Yellowbird RS's Avatar
yes! here you have the link for DIY http://www.pelicanparts.com/techarticles/mult_gauge_face/mult_gauge_face2.htm
X/A
Old 04-16-2007, 10:26 AM
Tree-Hugging Member
Jim727's Avatar
There are two articles on getting a clock running again.
http://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair.htm
and
http://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair2.htm
Have repaired mine though didn't want to go through the solder hassle. Found a thermal fuse made by NTE Electronics (800) 631-1250, part NTE8118, that can be used to replace the fusible solder link. If I ever get some free time I'm planning to write it up.
Jim
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 04-16-2007, 11:17 AM
You Guys Rock!! Thank you Yellow Bird!
Old 04-16-2007, 11:22 AM
