Lower valve cover gasket replacement questions
1) Should I use loctite?
2) Should I use a lubricant between the gasket and the cover?
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 04-16-2007, 09:53 AM
81 911 SC's Avatar
You should only use the nylock nuts and washers when replacing the covers. Never use any lubricant between the gasket and the cover.
- Tyler
1988 911 Carrera Grand Prix White/Black
2015 Cayenne Diesel Black/ Luxor Beige/Black
Old 04-16-2007, 10:04 AM
thx
Sean
NASA GTS2
Old 04-16-2007, 10:14 AM
Slumlord
Porsche_monkey's Avatar
I have to wonder why everyone is so adamant about not using any sealers on the surface. Even when I polished my valve covers flat, used a new gasket, and torqued it to factory specs, it still dripped.
I could see the reasoning if they never leaked, but a lot of them do leak, so why not use Curil-T or Hylomar?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-16-2007, 10:32 AM
81 911 SC's Avatar
I upgraded to the silicon valve cover gaskets and have no leaks. Porsche did not use anything when they built the car. I would think you run the risk of introducing something that does not react well with the gasket.
- Tyler
Old 04-16-2007, 10:46 AM
randywebb's Avatar
sealants cause a big mess
I'm surprised they leaked after sanding!
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-16-2007, 11:07 AM
