72' 911T Brake Lights
Hi,
The brake lights on my 72' 911T stay constantly on. There's no change in brightness when I press on the brake pedal. I've removed and inpected the switch that's on the master cylinder. The plastic piece at the end is still very springy. Not sure how to test it. I've also removed the two wires to the switch and the brake lights stays on. Can y'all help to point out other trouble shooting areas I can look into?
Thanks,
Ducky
Old 03-02-2022, 07:33 PM
Not sure what year they changed it but my 71 has the brake light switch on the pedal cluster under the pedal board. There is a lever and adjustment screw on the switch to set the amount of pedal travel before the brake light activates. I have no idea if it is the same on a 72 or not.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 03-02-2022, 09:49 PM
Here is the post I made a few years ago with the details
https://forums.pelicanparts.com/porsche-911-technical-forum/1061085-stupid-brake-light-question.html#post10867986
Old 03-02-2022, 09:52 PM
Titanium User
The wires on the master are for low fluid I believe, check your brake light switch under the pedal board at the brake pedal.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 03-02-2022, 09:55 PM
Originally Posted by Hi_Fi_Guy View Post
Thanks Brian!
Old 03-03-2022, 06:33 AM
Thank you!
Old 03-03-2022, 06:34 AM
Problem solved. Pulled out the brake switch and made some adjustments per Brian's post. I also bent the lever slightly so that it doesn't pop off which caused the circuit to stay closed. I'm new to these Longhood 911's, so it's a learning process for me. Thanks for the quick reply. Here's some pics of Eggsy
Old 03-03-2022, 02:14 PM
