Need help! Weird buzzing sounds!?
So recently my car started making a weird loud buzzing noise from the fuel pump or at least it sounded like it came from there. It wasn’t a constant noise but it continually got worse. I had the fuel filter and pump changed out and it seemed to run better and start up right away no issues. However after driving it the last week the sound is coming back!? Seems to be getting worse too. I’ve attached a video of the condition before the pump was replaced and the sounds aren’t as bad now but still do happen in small spurts. I wonder if the pump wires are touching something causing the sounds? I’m at a loss. I’m going to replace the fuel pump relay just in case that’s part of the reason and add some fuel injector cleaner. Any suggestions? Anybody have this issue? I’ve attached the video link below.
https://youtube.com/shorts/dlPg-_gBCaE?feature=share |
i wonder if your strainer in the fuel tank is clogged up or you have a pinched fuel line?
Ivan |
It seams like the noise is only heard when you turn left. Is it possible that your steering linkage is binding on your fuel line ?
Is the fuel pump vibrating against the housing or the skid plate. Or the bar that goes through there. I can't remember all the bits in there, but I do remember there isn't that much spare room.
I'm curious what yours is. I tried watching the video but it said unavailable when I clicked. I'm getting a buzzing sound in my carerra but mine is constant and has been there for years. Pretty sure its the pump. Let us know what you find out
What video ?
| All times are GMT -8. The time now is 07:24 PM. |
