-   -   Would you ever let a shop use the rear sway bar mount as a lifting point? (http://forums.pelicanparts.com/porsche-911-technical-forum/111395-would-you-ever-let-shop-use-rear-sway-bar-mount-lifting-point.html)
chrisp 05-20-2003 07:53 AM
I rolled my car into a shop and they swore up and down that the rear sway bar mount was the best place to put a lift pad under the rear of a 911. They don't see 911's often. I recommended they put it just foward of the torsion bar tube area... the same place where the usual P-car shops put it.
Just thought I would check with you guys to see if anyone has had a bad experience lifting from there.
makaio 05-20-2003 07:57 AM
I wouldn't, just because it's a PITA to replace one if it breaks.
john walker's workshop 05-20-2003 08:20 AM
just ahead of the mount.
1fastredsc 05-20-2003 08:24 AM
Good god no. Just ahead is better cause if my memory serves right, part of the chassis runs right there.
masraum 05-20-2003 08:33 AM
Uh, yeah, there or if they only have one lifting point in the rear they should use a chisel point wedged between the case halves.
It's amazing isn't it, you just have to wonder about people in shops sometimes...
Rick Lee 05-20-2003 08:42 AM
Those mounts are a Porsche-specific weak spot to begin with. Why would anyone put anymore stress on them? NUTS!
PCA7GGR 05-20-2003 09:22 AM
For pre-87s, ust in front along the seam of the tub. This holds true for the front as well. Late year Carreras and newer had built-in jackpads.
BGCarrera32 05-20-2003 12:48 PM
Why not right under the floor pan at each corner? Then you can drive home and pound it all back flat with a big rubber mallet, busting off all the sound deadening material like I did...
