Spacers
Hello
I'm looking for some wide spacers for the rear axle on my bastard 964 turbo look 911. It was modified and approved to wide body by a previous owner in 1997. He did however not bother to do anything to the suspension. To make things even "worse" I've bought some really nice 18" speedline replicas that has a larger offset than the ones that came with the car.
I need 87mm spacers, 90mm will allso work. Does anyone know where I can get spacers like this?
Best regards from Norway
Per
Old 12-22-2015, 12:21 AM
patz's Avatar
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
These guys will make what you need. But are you planning on using "spacers" which use longer studs? Or using "adapters" that have studs pressed into them and bolt to the original studs?
Old 12-22-2015, 01:44 AM
I will definetly go for adapters with pressed studs.
Old 12-22-2015, 05:05 PM
I have H&R wheel spacer for turbo look 964 in very good condition for front and rear I juat bought some RH WH Dip dish wheels so these H&R Spacers are for sale if you are interested contact me and I will send you pictures, price I will negotiate with you ,my mechanic made sure I buy the right size as rear are 50mm front are 28mm
my cell;(714)323-1169, I live in Los angels and my name is Sean you can text me if you wish
Old 03-12-2022, 05:20 PM
