 What is normal engine temperature in winter time What is the normal engine temperature for a 3.0SC and 3.2 Carrera engine during winter time. Thinking of a temperature range between 14 and 50 F.  My engine struggles to reach 185-190 F and only gets up to 158-167 F. with ambient temperatures between 32-41 F. Engine thermostat is ok. Wheel well thermostat does not open so that confirms that oil does not reach 185 F. Engine is run with DRIVEN DT50. That’s a 15W-50 grade oil designed for aircooled Porsche engines. Don’t feel comfortable revving the engine above 4500-5000 unless engine temp is up to 185-190 F. Any thoughts? Cheers Sent from my iPhone using Tapatalk |
 I have a similar issue and I’m curious about how safe it is to wind out if the engine temp never really gets warm even after an hour of driving in colder weather. |
 Really, those operating temps shouldn’t be an issue.  I’m in these cars (2.0-3.6L) every day in Colorado and it hasn’t been an issue with 20W50 or 10W60 oils. |
 My only concern with colder oil temps is not getting al the moisture out of them through evaporation. I like to have mine 180 or above to make that happen.  Are you sure the thermostats are ok? My car will sit just below the white line for about 90C/194F. At most it's 1 needle width below that no matter the outside temp is. It seems to me that, if the thermostats are working right, the engine thermostat should be partially open to hold temp in the engine. This gives you an idea of where on the gauge it sits, from another Pelican post. https://forums.pelicanparts.com/uplo...1240330010.jpg |
 When I've driven in those temperatures I'll only get to full operating temp if I start opening up the throttle at mid-range rpms. If you're just cruising down the highway you'll never open up the radiators. |
 FWIW - '88 3.2 - newly acquired in January after largely stored for over a decade. Slowly addressing various needs, but runs solid, and with temps between 30 and 80F in past two months, only once when pushing did the temp get to 194 - the first line. Typically during 30 minute drive at or above the speed limit (let's just call it 80ish), stays at least a needle width below the 194deg line. I'd call that 180ish... Sounds to me under light driving, your numbers are not abnormal. |
 https://i.imgur.com/UtQIDaXl.jpg This looks like a good temp to me... (Actually, throughout winter, my '81 SC's needle typically rests JUST above the white square box at the bottom of the gauge once the car is warmed up.) |
 TeeJay.....side note, what Tach is that? |
 What are those warning (idiot) lights indicating? |
 The oil pressure is at zero, and the rev's are 2,000rpm, not a good sign. |
 Tony |
 Originally Posted by Duc Hunter  View Post TeeJay.....side note, what Tach is that? the tach is from Speed Hut I use them in my Lotus Elan , great gauges, they use a stepper motor , this tach may have a hold last rev engaugd I do not think this engine is running I do agree with Tony. that temp reading is way too high 248* Ian My SC runs just at the top of the lower white box 180*, perfect oil temp |
 My '89 ran a hair under 180 when cold and a hair over when it's hot.  My current 2.7 the same.  The front oil cooler loop doesn't ever open unless it's hot hot out. I would have concerns if it were running much colder. |
 http://forums.pelicanparts.com/uploa...1647358607.jpg The first project I ever did for my 911 was to change the oil temp gauge with a numbered one. I have driven my 911 in cold temps. Below freezing and down to zero degrees outside. The engine will never get up 180, no matter how far you drive, at least mine didn't. The good news is the heater kicks butt, and pumps out lots of cold air to keep the passenger compartment warm. In zero degree or -1 it hardly gets off the 120 mark. I had the car in my garage, so it was 45 degrees at the start, but the temp gauge really never moves. I just kept the RPMs less than 4,000 and all was fine. In 20 degree weather after a two hour drive the temps might be 170, but never quite reach 180. I had my tach modified long ago as well to have a voltage meter right in front of my face. |
 i would suggest only one thread on the same issue.  verify the temp gauge is working. how did you verify the engine oil Tstat is good. it could be stuck wide open. |
 Yesterday in 75 deg. weather |
 Keep in mind too these cars are old. The ground to the engine could be not great, and that could effect the oil temp and pressure sensors. Same for the grounds behind the dash for the gauges. Lastly, only of my cars read like it was way off (can’t remember if it was to high or too low) for a long time. Turns out the wrong sensor was in the engine, changed that and it read fine. |
 Find something else to worry about.  Porsche recommends against sustained driving above 5000 rpm while the engine is cold.  Sustained.   The internals of your engine are sufficiently up to temperature after about 20 minutes of operation. The oil cooler and oil tank may be cooler, but your main and rod bearings are up to temp. |
 Supe - in the above picture the car is not running, must have just shut down. The Tach has a hold. |
 Ah.  I see.   What is the factory recommended specification for oil pressure in an engine that is not running? |
 I believe the car was off in that picture, but at idle my oil pressure gauge DOES read zero. When driving around, the gauge moves a heck of a lot, in very jerky movements with bouncing before it it settles on a number. I purchased a matching oil pressure gauge from SpeedHut but failed to realize that the sensor they send with the gauge is too long to fit in the 911's engine bay without cutting a nice big hole in the engine crossbar. Come to think of it, I should start a project car thread... |
 oil pressure looks hi to confirm oil temp. but i would still verify oil temp i ask again, how did you verify the engine Tstat is working . it sure sounds like its stuck open. mine was not stuck wide open but it was stuck open . it took a long time to warm up too. |
 Hi, Thermostat has been tested on the cooker in a pan with water and increasing temperatures and it works like new. Oil temperature has been checked with high quality infrared thermometer and also with thermometer probe directly in to the oil tank. Both measurements verified exactly what the original dash gauge shows. So the oil just don’t get up to 185-195F as it should, even after more than 1 hour of driving. Sent from my iPhone using Tapatalk |
 In my early m.y. '84 3.2, with original brass radiator and 104k mi., I rarely reach the 90* line all year in normal driving conditions - it takes a warm day in the desert and vigorous pace to climb above 120* and an autocross day to get somewhere in between, usually around 105*. |
| All times are GMT -8. The time now is 12:10 PM. |
