Mike the mechanic's Avatar
Question 915 selector shaft seal replacement
Hi guys, can the 915 tranny's selector shaft seal be replaced with the tranny still in the car? I would hate to have to remove the engine/tranny just for that little seal!
Mike
86 Carrera t
Old 05-26-2002, 08:30 AM
Senior Member
john_colasante's Avatar
Yes, as long as it's '73 and later. The '72 915 requires the seal to go in from the inside if I recall correctly.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 05-26-2002, 08:47 AM
Early_S_Man's Avatar
Porsche Crest
No, it's the input shaft seal on '72 AND early '73's that requires partial disassembly to replace!
Yes, the shift rod seal can be done in the car, and here is the Pelican Tech Article that tels how ...
http://www.pelicanparts.com/techarticles/mult_shifter_rod_seal/mult_shifter_rod_seal.htm
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-26-2002, 04:08 PM
You guys are awesome, John thanks for the info and Warren, thanks for the link!
Mike
86 Carerra t
Old 05-26-2002, 05:57 PM
Can someone help me with my shift shaft seal. I have been trying to pull the seal for a few day now and have had no success. I am following the directions from the tech article and the seal is not moving. I am using the cotter pin puller and a craftmans pick kit. My car is a 911 6/73. Please Help.
Thanks,
Matthew
73 T
Old 05-22-2003, 08:52 PM
