-   -   Power Window Operation Without Power (http://forums.pelicanparts.com/porsche-911-technical-forum/1114740-power-window-operation-without-power.html)
David Inc. 03-14-2022 03:40 PM
So I'm in the process of disassembling my SC for paint and I got myself in a bind. The door frames and glass need to come out but the power is already disconnected from the car and window motors. Any way to get the windows up and down without reconnecting everything? I hate those damned connections on the power window switch.
Showdown 03-14-2022 04:19 PM
Jump the connections with a battery?
john walker's workshop 03-14-2022 04:40 PM
Power and ground from your jumper battery to the two center wires that went to the switch from the motor. One way goes up, and other goes down.
David Inc. 03-15-2022 06:31 AM
Booo
Well I was hoping there was a disconnect for the motor but that's life. Thanks.
runner4fun 03-15-2022 06:42 AM
You can remove the motor from each side (3 screws) then you should be able to move the regulator and get the glass out.
David Inc. 03-15-2022 11:00 AM
This worked a treat, thanks. So long as I was mindful of the regulator not to pinch the cables and wires I was able to rotate the whole assembly to bring the window up and down enough to get the window frame out.
runner4fun 03-15-2022 11:03 AM
Great! Glad it worked. Now keep the Pelican thread on the window switch wiring as you are going to need that at some point. I just installed power windows in my 1973 911T and used that post to wire my switches. cheers, Greg
David Inc. 03-16-2022 05:43 AM
Oh I have a bunch of photos of the wiring for those plugs, I hate those damned plugs.
famoroso 03-18-2022 04:47 AM
I got tired of the power window switch wiring decades ago. A pack of multicolor metallic Sharpies later, this seems like the easiest solution...
http://forums.pelicanparts.com/uploa...1618850781.jpg
David Inc. 03-18-2022 05:44 AM
That's pretty clever, I like it.
runner4fun 03-18-2022 07:24 AM
Yes, I agree. Now what we need is someone to tell us how to convert from 5 pin window switches to the old style 4 pin switches with the chrome bezels. The chrome bezel switches look sharp in a back-date or older 911.
echecsqueen 02-16-2023 03:59 PM
Love this idea. Thanks !!
fallingat120mph 02-16-2023 09:31 PM
Older thread but glad I caught this...have 1000 photos of different repairs and this takes some of that out of the equation.
famoroso 02-17-2023 08:33 PM
I'm glad Pelican's are finding my tip helpful.
Ironically enough, I've since converted to manual windows on the '89 from the above photos.
Funracer 02-18-2023 10:08 AM
Great idea. Sometimes the simplest solution is the best.
