-   -   911 stopped running, won’t restart (http://forums.pelicanparts.com/porsche-911-technical-forum/1114875-911-stopped-running-won-t-restart.html)
MarkHoliday 03-16-2022 09:27 AM
‘89 911: Does crank but won’t fire. Let sit a day but then restarted and stopped again.
walt 03-16-2022 09:32 AM
Hopefully something simple like a DME relay. Might try swapping that out for a start.
lsf911 03-16-2022 09:32 AM
Well, not much information to go on but my first thought is a spark issue, a CDI that's failing.
I would start with checking the usual culprits...spark, fuel issues and go from there.
Walts suggestion is a good one...DME relay is an easy place to start
GH85Carrera 03-16-2022 09:55 AM
It could be the points on a old 911, or the crank sensors on a 3.2.
Mark, we need to know the year and of your 911 as a minimum to start to make guesses.
MarkHoliday 03-16-2022 10:14 AM
Thank you for the quick reply
AlKidd 03-16-2022 10:18 AM
Its easier to help when you say what youve tried and checked. Is there fuel in the tank?. Can you hear the pump etc etc etc
Rodsrsr 03-16-2022 10:21 AM
An engine basically needs fuel, spark, and compression to start.
We know it has compression, so next time it no starts, check for fuel and spark.
MarkHoliday 03-16-2022 10:55 AM
It’s an ‘89 3.2
As I say starts but will then shut down and not restart but does if I let it sit awhile. I thought crank sensor and responses saying DME relay are helpful places to check
Superman 03-16-2022 11:35 AM
To check for spark, my favorite method is to connect a timing light. If the timing light flashes, you have spark.
If you have spark but no fire, then apparently you don't have fuel.
