New Piston Rings WITHOUT Opening the case
Hey all. I've been tearing into my 1978 SC and a few heads studs were broken below the cylinder line, so i took them off.
Sadly..one the piston rings broke while doing so. A friend told me they've heard of people having sealing issues when installing new rings on the old cylinder heads. Any input or suggestions on this dilemma that i'm in? PFAhttp://forums.pelicanparts.com/uploa...1647463615.jpg |
Cylinders in these engines can usually be re-ringed without problems but the procedure has to be done properly. You would start by finding out what kind of cylinders they are. Alusil or Nikasil? They say Nikasils are better for re-ringing but I successfully re-ringed my Alusils.
Other questions are raised here also. If several head studs were broken, then your cylinders and heads may have taken a beating and will not seal properly when you reassemble the engine unless you have machine work done. Also, this is a good time to just have the heads re-done with new valves. Exhaust valves particularly. And guides and seals.
They're stamped Mahle and are magnetic, so Nikasil. Quote:
That's the plan. I'm sending the heads off to competition engineering here shortly to be rebuilt as needed. I was originally planning on leaving the pistons and cylinders alone, but here we are. |
Nope. Mahle make both Alusil and Nikasil but KS always Alusil.
I'm not following you. Why would there be sealing issues installing new rings in old cylinders? What is that supposed to do to the heads sealing to the cylinders?
As long as the head stud issue wasn't a long standing issue and didn't create any hot spots on the cylinder mating surface, I don't see why there would be an issue. I don't see any evidence of carbon blowing by the mating surface at the cylinder/head mating surface on the picture attached. |
Seems like my best option here will be to get a set of new rings and when having my heads rebuilt, i'll have the cylinders honed as well. |
I just read the title of this thread and realized how dumb it was. Swapping the piston rings without removing the heads...psh - what an idiot.
I meant to ask about changing piston rings without splitting the case. As I said, I haven't done this before, but I've only seen pistons & rods installed from the tops of the cylinders and then attached to the crank from the bottom. I found this video and it gave me the confidence I needed. (https://www.youtube.com/watch?v=jd82Hg9BbuA&ab_channel=KlassikAutomotiveTr ainingSchool) I'm going to speak to the machine shop that works with these early 911s and get their opinion (price). Thanks for all the input everyone. |
take the cylinders off, checkout the piston skirts and look for cyl scoring etc. If they look good, you can measure them for roundness and deglaze them and get your new rings and go to town.
Remember to place the ring gaps spaced out and with the gaps on the up side. (i think that was recommended in wayne's book.) But you are at this point, why not do the bearings too? Post a pic of the cyl walls when you can. I'm curious what the factory nik cyls look like because the alusils were quite unique looking that almost look like a gray paint. |
Kevin, I understood you had already removed the cylinders. Good to hear you are planning the things you should do while the engine is apart. I went ahead and replaced the rod and main bearings but golly, I wonder if anyone has ever worn out the main bearings in a 3L. I think these engines have seven main bearings, right? I might, if I were you, wiggle the rods back and forth to see if one is looser than the others.
If the machine shop fly-cuts your heads and cylinders, then deck height will be reduced and compression increased. Your choices include thicker cylinder base gaskets to raise the deck height again. Your choices could also include simply allowing the higher compression. You might want to do the math and consider higher compression. In a nearby thread, Jeff Higgins says his engine is 11:1 and he uses pump gas. Hmmm.... John Walker measured my cylinders at rebuild time. 186,000 miles. The most wear he could find was .0015". Miniscule. My cylinders are Alusil, and I did nothing to them except wash them very aggressively using parts solvent. It changed the color of the business surface from dark grey to light grey. The new rings seated just fine. Engine never made smoke. Bruce Anderson advised me to start it with my driver's license in my pocket, then drive it like I stole it. Force those rings against the cylinder wall with compression. Nikasils are a complete different animal, and I think they recommend a slightly more aggressive 'roughing' of the business surface. You can NOT use an abrasive on Alusils. Nikasils are different. Again, others know much more than I. |
Now I see your car is a '78. You could consider better pistons. 8.6:1 CR pistons leave a lot of performance on the table.
Okay so all you have to do is get one of the circlips out WITHOUT dropping it into the cylinder bore of the case, then push the piston pin out. I put the piston I'm working on at the top of the stroke then slide the cylinder up until I can see the piston pin. Then you CAREFULLY remove one of the circlips and push the pin that holds the piston to the rod out far enough to remove the assembly. On the bottom of the cylinder there's a half moon shape that allows the piston pin to slide out. This is how I take the cylinder and piston out as one unit. Make sure you bag and tag pins so you know which cylinder they belong to and make sure you mark the cylinders so you know where it goes. And buy a sleeve type piston ring installer. It makes the job SO much easier. I'll post the one I used later. Oh and you install the piston back into the cylinder from the bottom because the cylinders have a taper.
Sometimes....when you are removing one of those circlips....it suddenly enters another dimension. One moment it is there, and the next moment it is gone. It travels through a wormhole, visits other dimensions, and sometimes comes out at the other side of your shop. Sometimes. Or in the engine case.
The piston ring tool is a Wiseco ring sleeve. summitracing dot com/parts/wis-rcs09500 The circlip tool https://www.pelicanparts.com/More_Info/STOMSKISR072.htm?pn=STOMSKI-SR072&gclid=Cj0KCQjwuMuRBhCJARIsAHXdnqOofx7ORGq1ei 9R16_3eF3xhMjnMGIIecw8YV6iqCXsj7HfJBgLqUsaAhEUEALw _wcB BTW, do you have Wayne's book? It's a HUGE help. https://www.pelicanparts.com/catalog/accessories/rebuilding-porsche-911-engines.htm |
Really hoping to change the rings without removing the pistons. Seems like each time I take something apart, something new goes wrong:rolleyes: |
| All times are GMT -8. The time now is 06:19 AM. |
