Early longhood dash upgrade
Has anyone tried to upgrade an early longhood dash to a mid year with the center vent? I was considering this but was concerned about the amount of metal I needed to cut out and how this might weaken the dash and ...
Old 03-13-2022, 03:42 PM
lateapex911's Avatar
So, bigger question...what would you do with the vent?
And....the longhoods are bringing such big money, I'm not sure I'd change something that involves cutting and...the dash isn't a bolt on bolt off affair.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 03-13-2022, 10:18 PM
I was thinking for fresh air. The car is apart and dash and glass out so that’s not the concern. I just didn’t want to cut the metal and see that it becomes a much bigger modification...
Old 03-14-2022, 03:56 AM
Want fresh air? Roll the windows down and open the quarter windows. Lots of fresh air.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 03-14-2022, 06:44 AM
The center vents on the later dash aren’t going to blow you away. Hardly worth updating a long hood dash, in my opinion.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 03-14-2022, 06:50 AM
I converted my 75 from a no-vent-dash to an SC style vent. Was pretty easy. I bought an ABS BRUM made dash top, had it covered in vinyl to math the door tops etc, bought the SC vent and the plastic manifold that feeds the vent on ebay....and the tough part for you......CUT THE HOLE IN THE METAL UNDER THE DASH. My car is a resurrection project from a car that was not restorable to original.....your milage may vary.
you might be better served to get different heater vents that bolt un under the dash. They are a 5 in swap each, and if you get ones that blow at you (like many use for AC etc) they will blow a surprising amount of air at you to help cool you, without cutting anything.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-14-2022, 07:23 AM
PM sent on what I am doing w my 1973 911T dash. It's your car.
cheers
Old 03-14-2022, 07:56 AM
evan9eleven's Avatar
Maybe this helps? Kool’n Duct
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 03-14-2022, 03:27 PM
So I took the plunge and cut a rectangle in my dash. Really not hard. Thanks for all the suggestions and pictures Greg!
Old 03-20-2022, 03:20 PM
Paul, happy to help. I also took evan9eleven's suggestion and bought 2 of the Kool'n Ducts for the under dash ventilation. Just trying to get some fresh air moving in the old 911T cabin. Good luck with your project!
Old 03-20-2022, 03:42 PM
