Michael
Danske fuel tank
What are the steps to prepare a new tank for install? Searched and didn’t see a thread on this. Curious before I keep trying to clean the rust out of my tank
Directions say to rinse inside with some sort of solvent to remove their preservative coating.
More cars than sense
Are you just asking about functional steps? Or do you want it to look factory-correct as well?
Michael
I guess it’s just mineral spirits to clean the inside. I realize the outside is gets an under coating like the factory did. I’d like to better understand the functional steps. I believe the lines are all about the same as my 74 tank. Not positive the year of tank I have but I’ve got the little bowl inside the tank. My section in return on the bottom are 12mm.
Michael Gideon- Youtube https://www.youtube.com/channel/UCBqH-YRHqeuEnAQJTrljDdg GP 88 coupe, Olive 72 E coupe, Viper green 73 Targa, 2013 cayenne diesel |
The top breather outlet was too big on the one I used in my '79. Otherwise, it fit fine.
will an SC (78-83) fuel tank fit in a 1973 911T? I presume so
I've got one going into a '76 Targa resurrection. Plan on black stone guard all around, then light gray paint on the frunk side.
Michael
thanks John that helps
