901 transaxle help
I wanted to change the gasket under part #19 on the attached as it was weeping but now I can't figure out how to properly insert that fork back into the transaxle. Can anyone offer some help?
Old 03-23-2022, 01:30 PM
Engage #16 into the shift rods and then insert#19 over it so it's captured.
206 637 4071
Old 03-23-2022, 02:00 PM
kevingross's Avatar
What John said. If you have the "dongle" #16 resting in the square recess in one of the shift rods #2 #1 #5, then the tines in the cover plate should span the dongle, and the cover plate line up properly with the case studs.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 03-23-2022, 03:19 PM
Thanks for the replies. #19, does it go with the forks facing up or down? My recollection is up but I'm not sure now.
Old 03-24-2022, 03:52 AM
Studs are offset, so only will go on one way.
206 637 4071
Old 03-24-2022, 05:56 AM
