drives fast
Capt. Crunch's Avatar
How hard is it to weld those 911 mounts to the 912?
Has anyone done this already? I have a 912 that must fit a 2.7..........
Old 05-20-2003, 02:11 PM
SteveF_911's Avatar
I have done it.
It is not hard at all if you can weld, you just have to remove those little brackets across the back corner and then weld in the mounts.
Watch out the steel is pretty thin.
Best of luck, I did the conversion over a weekend, hardest thing was finding the flywheel.
Cheers
66 911 with S engine
2008 Westfield XTR2
Old 05-20-2003, 02:48 PM
pjv911's Avatar
Send a message via AIM to pjv911
Need the flywheel ? I have a 69` flywheel(push type) and an almost new sachs OE clutch . $150.00 + shipping.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 05-20-2003, 05:31 PM
SteveF_911's Avatar
How did you find a flyweel for $150?
I had to get one made from a billet of steel, cost me $450 AU. But it is about 20% lighter than the std Porsche flywheel.
Have fun with the project, they can be never ending.
2008 Westfield XTR2
Old 05-20-2003, 08:15 PM
pjv911's Avatar
It is a standard factory issue 215mm flywheel used from 67-69` . Thats what you must use for the 901 tranny . I have 2 of them . And 3 counting the one in my car.
Kurt
BTW when I needed the one for my car I had to buy it new from the dealer. I think it was over $350.00. Maybe over $400.00 . Had to have it !
Old 05-20-2003, 08:33 PM
SteveF_911's Avatar
I could not find one anywhere in Australia.
Flying one over from the States would have cost me about $800.
The light weight flywheel helps a short stroke enginge rev real quick.
2008 Westfield XTR2
Old 05-20-2003, 09:22 PM
dimps8's Avatar
Thanks Capt.Crunch, keep pushing the value for original early 912's up. Check the 912 board, I remember some mention of conversions and engine mounts.
Damon Harris
66 912 coupe
Old 05-20-2003, 10:00 PM
Bird. It's the word...
Fishcop's Avatar
That avatar rocks!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-21-2003, 04:04 AM
