901 transaxle help
I wanted to change the gasket under part #19 on the attached as it was weeping but now I can't figure out how to properly insert that fork back into the transaxle. Can anyone offer some help?
Engage #16 into the shift rods and then insert#19 over it so it's captured.
What John said. If you have the "dongle" #16 resting in the square recess in one of the shift rods #2 #1 #5, then the tines in the cover plate should span the dongle, and the cover plate line up properly with the case studs.
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
Thanks for the replies. #19, does it go with the forks facing up or down? My recollection is up but I'm not sure now.
Studs are offset, so only will go on one way.
