-   -   930 turn indicators stop after about 10 clicks (http://forums.pelicanparts.com/porsche-911-technical-forum/1115316-930-turn-indicators-stop-after-about-10-clicks.html)
coldwalls 03-22-2022 07:28 PM
Issue just started today. When I leave the turn signal on, it stops (turns off) after about 10 clicks, give or take. If I return the turn signal bar to neutral and return it to left or right, it'll start up again, usually about 10 times (anywhere from 4-16 really). This happens both for left and for right.
Checked the forum but didn't see any posts specific to this issue. Is there a shared relay that's wearing out? Any pointers are appreciated.
'88 911 carrera.
Thanks!
MichaelSJackson 03-23-2022 05:32 PM
Have you looked at the Porsche Turn Signal/ Hazard Flasher Relay (4 pin)?
I haven't seen this particular failure mode, but...
coldwalls 03-23-2022 05:33 PM
I haven't, but that'll be my first thing checked. Oddly enough, it wasn't having the issue today, so it's something intermittent. Maybe that relay is about to fully fail.
Bill Douglas 03-23-2022 05:46 PM
Have a look at a wiring diagram to get the wires colors and follow them to a flasher/blinker thing in the trunk area behind speedo etc. My SC one died and I just replaced it with a generic one that woks fine.
maninblack 03-23-2022 08:46 PM
I had a similar issue years ago. If memory serves me, it was a bad ground.
targa80 03-24-2022 12:09 AM
Here is a post I did on the turn signal relay in my SC.
https://forums.pelicanparts.com/porsche-911-technical-forum/819548-flasher-hazard-mods-my-80sc.html?highlight=Turn+signal
This other post has pictures of the mod to flasher relay circuit.
https://forums.pelicanparts.com/porsche-911-technical-forum/850904-911-turn-signal-indicator-issue.html?highlight=Turn+signal
