Classic Retrofit Gen 2 blower has arrived
Just came in today. I'll be doing an indepth comparison, but here is a teaser. The ac line connections are now on the drinker side.
EDIT:
For those that came for some numbers (note* numbers were taken on full battery with car off, numbers will only increase with car being on and driven)
Stock : 19mph single out
Gen1 : 25.3mph single out
Gen2 : 33.3mph single out
~32% increase in air coming out
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 11-15-2022, 04:40 PM
following.
Looking forward to your review.
Old 11-15-2022, 05:20 PM
Targa_PB_78_SC
mike sampsel's Avatar
Good to see it's in good hands. I'm sure you'll let us know how you compared them.
BareRearedRookie
Old 11-16-2022, 06:35 AM
spoke's Avatar
Nick, what has changed from Gen1 to Gen2? I haven't installed my Gen1 yet.
Find Spoke's LED Products:
www.spokeworksled.com
Old 11-16-2022, 01:03 PM
Senior Member
It is hard to not just jump on this and install now to get rid of some of the Octoberfest engineering under the hood. It also, over time, cushions the blow of the total cost for the total package with the household comptroller.
Looking forward to reading more about this...
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 11-16-2022, 01:38 PM
Jerry - will hopefully fix the issues the preventing it from being the go to choice for AC. The 964s don't have this issue since they already have a more powerful blower. I took a vid of the speeds on my gen1 blower through the vents with various settings. Will do one more just out the side on the old and compare to the new. Stay tuned...
Old 11-16-2022, 02:14 PM
CBA CBA is online now
Thanks for doing this… I bought a complete system a couple years back and never installed it because there was so many pros and cons to the system. Hopefully this is the ticket to get it to the proper level for such a big investment
Old 11-16-2022, 09:44 PM
Not alot of detail on the website so will be interesting to see Nditiz's comparison.
https://www.classicretrofit.com/collections/electric-air-conditioning/products/high-power-blower-for-911-a-c
Old 11-16-2022, 10:53 PM
Excited to see the differences. I've got my blower installed, but not the rest of the system. I consider the fan to be... "adequate". Not much more. If it's a marked improvement, I may need to upgrade.
Old 11-17-2022, 08:46 AM
Jonny H's Avatar
In true Porsche fashion, it doesn't look much different to the last one ! We do listen to feedback so we have focused on air flow increase and some installation niggles:
1. The internal blower fan is now rated 502 CFM, up from 292 CFM (measured at a static pressure of 10mm H20)
2. The evaporator is latest tech 38mm core offering less air restriction for the same cooling capacity.
3. The expansion block (TXV) has been moved to vehicle RHS, making installation easier on LHD vehicles with brake boosters.
4. The drain tubes have been made more robust.
5. The lever on the front has been moved across as some early LHD vehicles have short cables which were struggling to reach.
6. A cap has been added to the top of the unit to allow easier access to the evaporator for cleaning/replacement.
Old 11-17-2022, 03:08 PM
spoke's Avatar
The improvements look good. For those of us with a GEN1 unit still in the packing box, how do we get a GEN2 unit and what is the value of an un-installed GEN1 unit? Can a GEN1 unit be updated to GEN2?
Old 11-17-2022, 08:11 PM
7783911's Avatar
For those us us without AC, is there a blower replacement option for the sake of the blower only?
Old 11-18-2022, 11:19 AM
Sure, you could buy and install this one. I have a feeling a lot of the Gen 1 blowers will be available after my review, which is still more powerful than the stock one.
Old 11-18-2022, 11:27 AM
Gen 1 removed
Current tests with anemometer
Gen2 : coming soon ******* 33.3mph single out!!!!!
Old 11-18-2022, 12:17 PM
Sweet! Looking forward to hearing your feedback on the upgrade.
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 11-18-2022, 03:03 PM
Very nice!
Old 11-18-2022, 07:33 PM
Thé News gets better!
A personal appeal to any one who’s solved the condenser capacity problem. I can’t get past this issue on my SWB. I need to be satisfied with this before my much delayed install.
Bill
(No launch control needed)
Old 11-19-2022, 06:26 AM
@Bill - not sure what you mean by condenser capacity problem. You are having trouble running 2? There are tons of options.
Old 11-19-2022, 07:46 AM
MikeD930's Avatar
I have a Gen 1 system...can the Gen 2 blower fan be installed within the Gen 1 blower box or would I have to replace the whole blower box?
MikeD '87 930
Old 11-19-2022, 08:56 AM
Afraid it's a complete swap out. Haven't heard of a retro fit.
Old 11-19-2022, 12:55 PM
