2.2 engine removal
I'm pulling the engine out of my 70 911. Where is the best place to remove the oil lines? At the tank or at the engine? I have all connections soaking in liquid wrench so it should be loose by morning.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
You do not have permissi
Couldn't say, but the safest way would be both ends and new o-rings for the cooler.
Also, try PB Blaster for a penetrant in rusty spots. |
It doesn't really matter so much but be ready with an oil pan and some paper towels. I believe i removed the oil lines that were attached to the engine when i pulled my 2.2.
Patrick
pod911@gmail.com |
I always take them off at the tank. On my '67 there is a few clamps that attach the longer line to the engine, and they are much easier to get to with the engine out.
Doug '67 911 2.2 |
Follow up ques. The nuts on the tank are massive 36mm and one is 32.5 mm if my memory serves me right and I got the dial calipers in there correctly. The half size nut doesn't make sense and it has what looks like a split in it. Does it require a special wrench? I know these tanks are expensive so I don't want to screw it up.
I just use a large adjustable wrench. I don't remember anything odd about the nuts, other than one is a inside fit and one a flanged compression nut. They do take a bit of force to get them off. There is no place for a back up wrench on the tank side, so I guess we just have to hope it is on there solid. I don't know if your '70 is different than my '67. Good luck!
Doug '67 911 2.2 |
